Old 05-18-2016, 04:50 AM   #121
It is recommended differential balls?
awizner is offline   Reply With Quote
Old 05-18-2016, 11:23 PM   #122
Originally Posted by awizner View Post
Perfect. I'm sorry but my English is not very good .. I will try to explain as best I can .. I will mount the optional engine plate to prevent the transmission is broken by blows or use very powerful engines. I will use silicone Hudy 1000000 . Brushless motor that is recommended? 21.5 or 17.5 ? Is there any part that is necessary also to change?
1) I recommend brushless 13.5T or above (17.5, 21.5, etc) or Brushed silver cans, black cans are ok... anything faster the gears will be easily stripped.
Please make sure that you are running in NA / Blinky mode - which means No Boost, No Turbo mode.
2) I recommend to double check all bearings inside and outside the gear box are smooth, clean, and oiled so there wouldn't be any issues. (especially the 2 small ones inside the gearbox) - I personally change them every half a year or so.
otaku521 is offline   Reply With Quote
Old 05-18-2016, 11:24 PM   #123
The ball diff seems to run smoother than gear diff IMHO... but you will need to remember tighten the ball diff once in a while.
Old 05-19-2016, 01:49 AM   #124
Ok , I will review the bearings every 6 months and give you oil frequently . Finally I will ride 17.5 LRP brushless drive spx with zero . The servo SAVOX 1251 will be the low profile black edition . It is recommended to mount an optional or piece more durable ? For now has used the differential gear to see what result gives
Old 05-19-2016, 02:28 AM   #125
you can use the original motor mount and see if it is ok...
It is just the original silver motor mount is easily tweaked (Bend) in a big crash which might make gears inside to chew up
you can try by putting the motor mount plates on a piece of flat glass table and see if it is bend or not.. if it is.. I recommend getting the thicker optional ones or even the one made by Jet Racing (They are even more thicker than the optional one made by ABC)
Old 05-19-2016, 04:14 AM   #126
reference is GA - 02T?
Old 05-19-2016, 06:48 PM   #127
http://jethobby.com/_shop/product/pr...l.php?id=18332
Yes it is GA-02T - it is a little thicker than optional ABC hobby made one
Old 05-22-2016, 01:46 AM   #128
32819toon's Avatar
I've bitten the bullet and ordered the Naked from RCMart, plus steel gears and extra springs. I'm going brushless 17.5t , possibly boosted. Can't wait to try it out !!
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 05-22-2016, 06:58 PM   #129
boost - I wouldn't recommend to set it or set it too high... as I have chewed my diff gears when I had my set to boosted 13.5t
congrats on your new car!
Old 06-10-2016, 04:57 AM   #130
Good morning. I mounted aluminum steering system and I have a problem .. I 'm screwing the plate suspension and will not let me turn the steering system . They can send a picture of how it is mounted ? Thank you!
Old 06-10-2016, 07:36 PM   #131
use countersink screws rather than button head screws... put a 1mm or 0.5mm space in between the bearing and the screw this should work
I know the manual said to use button screws... but I spacer + countersink screws works for me
Old 06-12-2016, 10:51 AM   #132
The Big Wig's Avatar
Default Grande Gambado
Anyone running the Grande Gambado against other front motor FWD's?
The Big Wig is offline   Reply With Quote
Old 06-12-2016, 03:13 PM   #133
Trader Rating: 4 (83%+)
result of IRCC 2016 in japan fwd class
FWDクラスQualify#4を終了しての結果です。
【】内は使用シャーシメーカー。
1) Kazuma Morita 22/4:02.978 (R2)【SPICE】
2) Akira Furuhashi 22/4:03.200 (R3)【SPICE】
3) Tsuyoshi Yoshinouchi 22/4:05.735 (R3)【3Racing】
4) Kazushige Kato 22/4:07.081 (R4)【SPICE】
5) Scotty Ernst 21/4:02.570 (R2)【3Racing】
6) Nobuo Tanii 21/4:05.218 (R4)【ABC】
7) Akira Sone 21/4:06.528 (R4)【VBC】
8) Toshiyuki Kitai 21/4:06.711 (R1)【ABC】
9) Kenichi Suda 21/4:06.748 (R3)【ABC】
10) Takao Mishina 21/4:07.472 (R4)【TAMIYA】
Xray T4 2017
Yokomo BD7 2015 Spice FWD
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Quinny45 is offline   Reply With Quote
Old 06-22-2016, 02:25 PM   #134
32819toon's Avatar
1st race tonight with RcMart version & I love it !! Kit rear tyres, Shimizu wet hard front, Kit front oil, 30wt rear, red springs up front, yellow rear, handled great on carpet.
Can't wait for next time ☺
32819toon
Old 07-01-2016, 07:40 AM   #135
Default Metal gear differential
Has someone tried to replace the 48T 48P plastic spur in the Gambado ball differential with a metal one from some other brand?
Original part:
ABC Hobby 48T Gear For Ball Differential #25781
Mr.Marmot is offline   Reply With Quote
