Old 01-07-2016, 06:28 AM   #91
YES!
I received my car version route 246
It's very Nice, i like it!
(sorry i want to put some photos but i don't have a certain number of posts)
For the body, I'm hesitating between a mini and a alpine a110 (is it possible to take an alpine?)...
Do you think that Aluminum Steering Set is usefull? and the 24143 differental-adjustable?
i've to order some parts (steel gear, pinion, springs),
for the motor, I have a 10.5 for outdoor, and a 21.5 for indoor.
TAPASMAN is offline   Reply With Quote
Old 01-07-2016, 09:10 PM   #92
Originally Posted by TAPASMAN View Post
YES!
Congrats on your ABC Gambado!
1) Body: I am running Colt Porsche & Blitz RX4 - the original Kit's ABC Mitsubishi Colt makes the run very nervous and tipsy.
2) Aluminum Steering does make it steer more smoothly - but as long as you plastics ones are new and smooth - I personally don't see much difference - but once it get worn out and slops and have plays - I can see you can upgrade it.
3) 24143 Diff screws set - the only thing that I have used is the diff balls and the diff grease - that long screw isn't that great because the screw head get stripped easily - You are running ball diff now?
4) Metal gears - I do recommend to get the metals gears and remember to screw lock glue that screw that holds them - just a tiny tiny drop is OK.
5) Currently in my local asphalt track (Temperature now in HK is 16-20'C) running: (For your reference)
a) Team Powers 36 M Chassis Tires (using mighty grip v3 yellow can dope for 10 mins)
b) Front Blue / Rear Yellow Springs
c) 13.5T Motor (3000kv)
d) Hobbywing 60A ESC (Blinky, No turbo, No Boost - Punch is set 2nd lowest)
e) D/R: Steering setup 85%
f) Front: Toe Out 2' / Rear: Toe In 2'
g) Height: Front 4.8mm / Rear: 5.0
otaku521 is offline   Reply With Quote
Old 01-08-2016, 03:26 AM   #93
Thanks a lot for this informations;
yes there's one in the r246 version
Old 01-13-2016, 07:04 PM   #94
Tapasman - so how is it? please share your settings for us...
One thing I kept forgetting to tell you - Don't get the aluminum Turning Rod (25755) - If you crash or someone hit you hard, it will break or bent easily.
Use Steel Turning Rod (25664) instead
Remmember - always buy Steering Rod Ends (25674) if you replace it - because the rods does not come with it (ABC WHY?!?!?)
Old 01-13-2016, 07:32 PM   #95
On Another Note:
I am thinking of DIY to make my Ball Diff into a solid axle -
Instead of installing those tiny little balls into the gear I am thinking of drilling and replace those slots with 4 tiny screws with screw lock glue or a thin nut
Since most of us are running very high diff oiled front anyways - why not making a Solid Axle instead (Yes I know coming out of corners might oversteer and turning circle might be different (larger?))
If this is a go - I might look into possibility of looking maybe a metal gear instead of the plastic ones? (As this will hopefully solve gear chewing issue?!? - and maybe have possibility to run faster motor? or ESC settings (with turbo/boost)? as I would love to see that I am an ABC Gambado M Car passing over T4 and BD7 and seeing their eye pop...)
(Yes I know the tires might empty spin on faster motor settings)
Please tell me what you think of my idea - before I take out my drill and breaking things XD
Old 01-21-2016, 08:49 AM   #96
Hello, i have the parts i ordered, but actually, i don't have time, i'll come back to the forum when the car is ready...
I took a morris mini cooper body
Old 02-04-2016, 11:47 AM   #97
Hello, i'm working my gambado
What oil i can pût inside dampers? For carpet? I have red and hello springs
Old 02-04-2016, 06:29 PM   #98
For Carpet - I really don't know...
For Asphalt - my dampers / springs are:
Front:
Damper: 60wt (800cst)
Spring: Blue
Rear:
Damper: 40wt (500cst)
Spring: Yellow
It works for me in a medium size technical track with medium to low traction.
Old 05-02-2016, 03:07 AM   #99
Hello Otaku
first race on carpet, very good!
front:
yellow spring
40wt
PS-SM-G - Shimizu Treaded Tyres - Medium (with cyano)
rear:
yellow spring
40wt
PS-SM-R3 - Shimizu Treaded Tyres Mini-Soft
motor 21.5+0 TIMING
Old 05-02-2016, 03:09 AM   #100
ABC Gambado/Grid-4141822016041814475220160417161232jpgvisionneusedephotoswindows.jpgABC Gambado/Grid-20160417_163811_resized_3.jpg
Old 05-03-2016, 08:49 AM   #101
Drachenschorsch's Avatar
That´s a really nice collectiom tapasman.
I recently installed the steel counter gear shaft http://www.rcmart.com/hobby-25797-st...=595_1124_1666 and the steel spur gear shaft http://www.rcmart.com/hobby-25796-st...=595_1124_1666 which seems to have cured the gear problems. Fingers crossed.
Drachenschorsch is offline   Reply With Quote
Old 05-04-2016, 01:13 AM   #102
Fablous Tapasman!
it has been raining mad here in HK and I have been to the track for over a month already!
Old 05-04-2016, 02:22 AM   #103
it was a vintage race with 21.5 motor , we were 5, it was a great moment;
no problèm with the gambado, i like this car.
I can not post link to a video (You are only allowed to post URLs to other sites after you have made a certain number of posts. You have not reached that limit yet.) , you can type in youtube "rca amicale 17-04-2016 DTM standard"
Old 05-04-2016, 02:22 AM   #104
https://www.youtube.com/results?sear...amicale+17-04-
Old 05-04-2016, 02:23 AM   #105
it's ok now, i posted 10 messages
