Old 07-02-2016, 11:01 AM   #136
32819toon's Avatar
Heres mine. I love this car. 13.5t brushless Trackstar system, 1 million gear oil in diff, handles great.
ABC Gambado/Grid-20160621_192321_kindlephoto-4041855.jpg   ABC Gambado/Grid-20160621_192449_kindlephoto-4003133.jpg
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 07-02-2016, 08:06 PM   #137
Originally Posted by Mr.Marmot View Post
Has someone tried to replace the 48T 48P plastic spur in the Gambado ball differential with a metal one from some other brand?
Original part:
ABC Hobby 48T Gear For Ball Differential #25781
If you found one that fits... pls tell me too! I am looking for a solid axle that can replace the gear diff / ball diff - if there is one.. pls share!
otaku521 is offline   Reply With Quote
Old 05-02-2017, 02:30 AM   #138
NEWS
http://www.abchobby.com/JP/page/rc/gamb/gamb_25614.html
TAPASMAN is offline   Reply With Quote
Old 05-04-2017, 12:12 PM   #139
Originally Posted by TAPASMAN View Post
YES! it has couple modifications to the existing car...
ABC Gambado Naked 2017 Ver. First Look ? Team rcMart Blog
Red RC ? RC Car News ABC Hobby Gambado 2017 1/10th M-size FWD car kit
Here are some of the details of it in English from RCmart Blog and red RC above
Old 05-04-2017, 04:31 PM   #140
tony gray's Avatar
Sadly, they've done nothing to fix the problems with the spur gears stripping...
tony gray is offline   Reply With Quote
Old 05-04-2017, 07:13 PM   #141
If it is the spur gear that you have the problem - use the larger version grande gambado spur gear - which you will need:
New metal smaller gear
New durain larger gear
the new gear shaft
new bearings
ABC Hobby Grande Gambado CNC Counter Gear Set 50T / 20T #40609
ABC Hobby Grande Gambado CNC Counter Gear Set 50T / 25T #40608
These I have found have made the gears smoother and should solve the spur gear problems
but what I had in the past where the diff housing / gearing stripped - changing to these gear sets - the diff issues have never came back for me
Old 05-04-2017, 07:41 PM   #142
tony gray's Avatar
Interesting, I wasn't aware that they'd made those changes. Might be worth revisiting.
Thanks for the info.
Old 05-04-2017, 10:15 PM   #143
Also note the gear connected to the diff and outer spur gears have to change to 20 teeth as well
(Thus they are now both side 20 teeth)
Old 05-06-2017, 02:27 AM   #144
32819toon's Avatar
the new gear shaft
new bearings
I already have upgraded to metal gears, so is it only the Hobby Grande parts I need ?
32819toon
Old 05-06-2017, 06:04 AM   #145
Yes either grande gear kit would be ok
And again the outer small gear to 20
Old 05-06-2017, 12:11 PM   #146
32819toon's Avatar
Thanks Otaku.
I was hoping to race it tomorrow and stripped the gear box down which meant taking the entire front end apart which is very annoying. When I went to re-assemble the shocks I found I had lost a half top hat bushing which does on the top of the shock. So I'll order replacements and the gears. Are you recommending the 50 / 20 ones ?
32819toon
Old 05-07-2017, 12:59 AM   #147
Thanks Otaku.
I am running 48/20 (I brought everything seperate instead of the kit...)
because during the time the kit was sold out so I have to buy all the parts seperately
Old 05-15-2017, 06:59 AM   #148
Gambado with A110 body
Gambado with his friends
Old 06-10-2017, 05:28 PM   #149
caltek1's Avatar
Trader Rating: 36 (100%+)
Thanks Otaku521, the Grande parts have rectified my main issue with the Grid/Gambado of stripping the inner plastic gear. I actually made it through a complete day of racing with 3 qualifiers and a final. I used a metal 20 tooth gear on the outside diff shaft and coated my gears with silicone lubricant which made them less noisy.
I am in love with my Gambado again.
caltek1 is offline   Reply With Quote
Old 06-10-2017, 07:40 PM   #150
Most welcome! Hoped that it resolved issues that we all had 😜
What silicon lubricant that you are using? Mind telling me? I too looking for a better lube for the gears inside the gear box and outside with the spur gears too... because with metal gears running (20T and the new inner grande gambado metal gear ) you will see a little wear
