Old 10-14-2005, 06:39 PM   #1
Posts: n/a
Default Batteries Troubleshooting
I have a couple of sanyo 3600 stickpacks. One of them shorted i guess.
It cant charge at 5 amps and is stuck at around 3.1 to 3.3 amps...
One of the cells also sort of heated up the most while charging.
And the other pack .. it charged normally at my 4.5amps..
But i dunoe why it doesnt deliver any punch. it feels as though i m running an almost empty pack.
And i noticed on this pack, some cells have a few little dots of cracks.
Like something chipped off. Did those batteries overheat and crack?
Can assume their death ?
So my plan is to dismantle the packs to get it to be side by side packs.
BUT... i need advise on troubleshooting the batteries.
wad do i need and wad do i do ?
Thankz !
Old 10-14-2005, 07:29 PM   #2
alltech's Avatar
#1 who is than maker of these packs?The 3600 packs have been noted to have problems.I would check to see if all the cells are correctly soldered together meaning +-+-+- or vise versa....I had some 3600 matched packs i bought from a guy out of canada on ebay and they where junk.Even know everything was matched right the cells didnt have much punch and didnt hold a very good charge.
alltech is offline   Reply With Quote
Old 10-14-2005, 07:37 PM   #3
Posts: n/a
the maker was some guy from a hobby shop ..
they used to work great with lots of run time and stuff...
but now ..
plz advise..
Old 10-14-2005, 07:40 PM   #4
Posts: n/a
btw.. my batteries are soldered end to end ...
meaning tat the batt pack doesnt have foil or something connecting inbetween..
Breaking apart really means BREAKIN apart ..
argh .. another problem..
Old 10-14-2005, 09:27 PM   #5
why not try dumping your pak . then putting them on an equalizing tray .. then charge them up .. if your not equalizing them be fore you charge there is voltage already in some of the cells .. which will cause one or more cells to heat up and your batteries will not charge correctly ...
Mark Barden .
mb racer is offline   Reply With Quote
Old 10-15-2005, 01:15 AM   #6
Posts: n/a
er.. dumpin meaning ?
charge full and then discharged fully ?
revo troubleshooting lionheart912 Rookie Zone 1 07-30-2007 06:04 PM
M11 troubleshooting GASKET98 Electric On-Road 11 03-17-2006 11:38 AM
troubleshooting dakrat Painting, Designs, Graphics and Photography 3 05-02-2005 10:38 PM
Troubleshooting Bull float Australian Racing 5 04-11-2004 05:55 AM
XXX-T Troubleshooting thousandAnd1 Electric Off-Road 3 05-09-2003 10:00 AM
SEO by vBSEO 3.5.0
