Corally 10sl
Corally 10sl
Hello
When I accelerate quick the car will spin out and also when I
Brake hard, if I am gentle on the throttle it performs nicely !!
Tekin 6.5 t motor
Would this be normal
And any other tips for setup on 1/10 235mm pancar
Regards
Tekin 6.5 t motor
Regards
Hi,
The car is probably tweaked and could be a few things.
An easy method to check is putting 2 coins on the front wheels, lift the front of the chassis with a small 1.5mm allen key in the small hole in the front center of the chassis.
Coins should drop at exactly the same time, if not the side springs in the rear should be adjusted.
However, I am not a fan of this method since it requires a perfectly built and tweak free front suspension.
Another method is a lot more difficult...
There's a 1/10 pan car thread under the larger scale section of the forum. No idea why they put it there....
That's fairly normal behavior for a pan car (assuming you're running it outdoors).
Softer rear tyres will make the biggest improvement.
