Old 10-08-2001, 05:31 PM   #1
Speedo's Avatar
R/C Tech Charter Subscriber
Smile Body Roll- When does it help you, when does it hurt you?
I want to start playing around w/ the roll centers on my yokomo, but I need some advice on where to start. I am on a high traction, tight carpet track. Most people would say less roll is better. Also, what about more roll in the front or visa versa?
Speedo is offline   Reply With Quote
Old 10-08-2001, 06:48 PM   #2
Cosmo's Avatar
Well, body roll is never a good thing. What you are thinking about is chassis roll. On carpet, less is usually better. What it is good for is low traction. What happens is this: pretend you are riding in a full size car. When you go around a turn, the car leans toward the outside of the turn. Well, that puts more weight on the outside tires. In R/C, that translates into more bite on the outside tires. On dusty parking lots, I have run as light as 25wt oil and green and silver springs on my TC3 (some of the softest) to make my chassis "roll" more. It puts more of the weight on the outside tires and makes the car track better. On carpet, traction is usually not a problem. The reason for not letting it roll is because it slows you down. When the car rolls, it unweights the inside wheels and in extreme cases can cause the diffs to unload and tires to spin. Increasing the chassis roll may suit your style of driving, but if your car is hooked up now, don't mess with it.
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 10-08-2001, 08:19 PM   #3
Speedo's Avatar
Yeah, I know...What really happens on carpet, is that since there is so much traction, in transferring weight to the outside tire, you loose more traction than you gain.
Old 10-08-2001, 11:11 PM   #4
Cole Trickle's Avatar
The good thing about chassis roll, is it gives extra weight on the outside wheel, therefor more traction. As mentioned above, it's only to a certain limit, where the inside wheel lift off.
But I think the downside is a little different than explained above; It takes time to transfer weight from one side to another, and thats the reason for the laps go down, when there's a lot of chassis roll. In other words, the less chassis roll, the more responsive the chassis is.
I usually set the camber links for as little chassis roll as possible. Then I work with tires, springs and shock oil. At last, I sometimes adjust the camber links for fine tuning. Lately that was needed in the back, because it tends to spin out. This method works fine on carpet.
Cole Trickle is offline   Reply With Quote
Old 10-08-2001, 11:50 PM   #5
... i guess you could use some body roll/chassis roll if your car is twichy on high speed.
stik is offline   Reply With Quote
G4S roll bar mod - change to mugen roll bar charlesd Nitro On-Road 13 07-01-2008 12:32 AM
Will i hurt the Buggy? hrnts69 Nitro Off-Road 6 05-24-2008 04:56 AM
LST2 body and/or roll cage wanted vtracer R/C Items: Wanted to Buy 2 02-13-2008 03:50 PM
Did I hurt my motor? shawn17 Onroad Nitro Engine Zone 15 09-03-2007 04:17 AM
Monster GT Roll Cage or Roll Bar complete or Plans? mjm R/C Items: Wanted to Buy 1 03-18-2005 04:12 PM
SEO by vBSEO 3.5.0
