Old 11-04-2016, 12:41 AM   #61
Originally Posted by thilo-alexander View Post
i use the vertical topdeck, for me a must have on asphalt
cause it reduce flex - front to rear - and adds a little more torsional flex - left/right resulting in more onpower traction,
something you can not get enough on asphalt.
on carpet i am using the vertical topdeck with aluminium chassis, it makes the car a little
bit more reactive and gives more midcorner without reducing onpower traction,
perfect for tight carpet tracks.
For more open tracks like ETS-Style i prefer the standart topdeck cause it makes the car a
little more easy to drive on highspeed corners.
I dont use the carbon chassis on carpet.
Maybe that helps
Thanks for your quick reply!
I just ordered my Lab TE03 evo with vertical top deck and alloy chassis.
Do you have Some basic setups for high grip ets carpet and medium asphalt? There are not that much setups on petitrc.
Cabocuts is offline   Reply With Quote
Old 01-03-2017, 02:13 PM   #62
Springs are different,
Drivetrain is same style but different material.
Greetings
hey champ i noiced you are using the REDS esc and Motor how do you find them?
at the moment im using reds esc and testing the new Tesla 5.5.
I have gone to the SMJ progressives springs seem to suite the track i run at.
New top deck is a good improvement for the cap, you can still adjust the flex front or rear to suite.
StevenS
StevenS is offline   Reply With Quote
Old 02-07-2017, 03:53 PM   #63
Trader Rating: 25 (100%+)
Front diff down, rear low
1.5 camber on all corners
1 toe out
2.5 rear toe in
Yellow springs all around
3 hole pistons, 550 weight
Alu chassis, regular top deck.
3mm shims rear inner bulkheads, closest hole to the tower. Same in the front. 2mm shims on rear hubs.
Make sure to apply CA to the tires sidewalls.
madness is offline   Reply With Quote
