Dear all,
My old Street Weapon IWC has been sitting on the shelf for years. (Still in pretty good shape, 80% new). I thought I could just get it back to running again. Then I realized all the belts were decomposed into crumbs of rubber. After weeks of searching, I also found out that Team Losi has discontinued the production for the Street Weapon rear belt. I notice the new JRS-X has a drive belt of 330mm (Compare to SW's 336mm). I wonder if that would help me solve the problem. Has anyone encounter the same situation? Who might give me a little advice?
Dear all,
Tommy
They have it listed on the site as LOSA3203 for the Street Weapon the XX-4 I think runs that belt as well.
Thank you all for the info's. The correct item # should be 3203 or 3204. I also read that xx-4 and Street Weapon have different chassis length. So the xx-4 belt won't cut it.
Anyhow, I wonder if the gear-pitch's are the same for all LOSI belt? If so, I believe the JSR-X could do the job.
Dear all,
Just picked up a used street weapon, came with two rear belts, "phew" but I need to pick up a front belt. fortunetley they're stil available. I am wondering if a longer belt could be substituted for the rear belt, if you moded in a belt tensioner like on my RDX. Would require cutting into the tunnel but hey
