NOT SURE WHAT THIS PANCAR IS HELP PLEASE
A lot of the parts on there are CRC...but it looks all mixed up. It likely isn't any specific pan car but one someone made out of random parts and cut up to fit a F1 body.
Didn't speedmerchant make an F1 conversion for CRC cars a while back? Might be one of them.
thanks for your help
can anyone identify what crc model most of it is like what chassis it would have been
Yup that's CRC's older F1 car...hence why I said the OP's one looked like CRC parts as it didn't look like a car CRC actually built.
The front train is CRC pro strut.
The rear pod seems indeed to be coming from SpeedMerchant...
All the other CF parts seems to be home-made.
thanks thats what i was after
The rear shock, shock mount, damper tubes, and the red stand-offs are CRC as well.
Didn't TOP make a F1 can with a pan car front end? It sorta looks like a Top F1 mashed with a CRC rear pod.
TOP does make an F1 with a pan car front end, but the car in this thread doesn't look anything like the TOP. For starters, the front end is definitely CRC and the tube configuration is completely different than the TOP. Also, the pod on the car in this thread is pretty clearly from SpeedMerchant.
