Like Tree61Likes
Old 04-11-2015, 10:44 AM   #61
Trader Rating: 29 (100%+)
Got mine finished up this morning. Build went great, zero complaints. Xray front ride height spacers work perfectly on the xenon front end. Looking forward to getting it out for some laps.
Roche Rapide P12 1/12 Competition Car Kit-image.jpg
branover is offline   Reply With Quote
Old 04-11-2015, 11:43 AM   #62
EDWARD2003's Avatar
Nice looking setup. However, I think your steering links are not setup correctly.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 04-11-2015, 11:59 AM   #63
Please elaborate
Old 04-11-2015, 12:10 PM   #64
hanulec's Avatar
Trader Rating: 27 (100%+)
Please elaborate
Brandon- you either need to shim the servo fwd or swap the ball studs on the servo saver to put the links forward
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-11-2015, 12:31 PM   #65
Easy enough, thanks. I thought a slight forward angle was ok. Is straight across preferred?
Old 04-11-2015, 12:57 PM   #66
kartermdb's Avatar
Trader Rating: 15 (100%+)
My links are just a hair off of straight across. They still slope towards the rear though.
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 04-11-2015, 01:31 PM   #67
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Slight forward angle is 100% ok, but what you have is a slight backward angle (the angle is described looking from the front of the car).
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 04-11-2015, 03:31 PM   #68
wingracer's Avatar
Trader Rating: 23 (100%+)
You want the links on the servo ahead of the links on the steering blocks.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 04-11-2015, 05:52 PM   #69
Thanks for the info. I've strived for perfectly straight in my other cars. Thought I'd give this a go. Apparently I misunderstood what I've read. I'm still very new to this and appreciate the info.
Old 04-13-2015, 06:35 AM   #70
All fixed up. I ended switching to a kimbrough servo saver, shimming the servo 1mm forward and using TOP low profile ball studs and it's perfectly straight across now.
Thanks again for the help
Old 04-13-2015, 08:02 AM   #71
miller tyme's Avatar
I'd be curious to see if that balances left to right, with the servo and ESC on the same side I would definitely check it
Ken Miller
RCTarget - Capricorn - Sanwa - Pro Level RC - MAX Power - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 04-13-2015, 08:48 AM   #72
It does with a 8 gram weight to the extreme right. The servo is temporary just so I can get the car out for practice, I have limited time to play. The chassis is only drilled to allow the JR servo mounted that way. I plan to use a different servo mounted to the right. Even with the 8 gram weight the car weighs 739 minus transponder that I haven't installed yet. I replaced all the stock screws with titanium/ aluminum where applicable.
I'll report back with final balance status and weight when I get the car truly finished. I may end up putting and older Orca 1S esc in it since they're a few grams lighter.
Old 04-13-2015, 11:30 AM   #73
Often times it will because the battery is so much lighter on the side with the plugs.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 04-13-2015, 03:16 PM   #74
Damn Mailman keeps leaving stuff at my door
[IMG][/IMG]
Ken Miller
Old 04-13-2015, 04:06 PM   #75
I ended up installing a Savox I forgot I had which I could mount on the right side. Balances perfectly now with no weights after some minor movement of other electronics. I installed the transponder and ended up at 735g ready to race. Can't wait to get it out now.
