Help!!!! does lrp phaser work with 3pk?
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Yes it will work. Just use the crystals from your radio. Actually it doesn't matter any set of FM 27mhz crystals will work.
It's only when you use 75Mhz do you need to worry about positive and negative shift.
