1/10 Pan Car Braking Help!!!!!!
Hi guys,
I have a corally 10sl 1/10 235mm pan car with a 6.5 tekin motor and Hobbywing XErun 90a v2.1.
I have calibrated the radio time and time again but the brakes don't seem to work when the chassis is on the ground.
In the air as soon as i hit the brakes the wheels stops dead as expected, but on the ground the car rolls like it's in neutral. For that reason surely it can't be the radio.
Is it my gearing? I'm running 66t/36t 48dp gears. But previously in my CRC pan car i had the same problem running a higher teeth spur gear and smaller pinion?
Any Help guys :s
Any Help guys :s
Program the brake strength in the esc.
Thanks for replying. I have the program card and i been making changes. All braking options are turned up, even drag which i don't even want. The effects however are only seen when the wheels are spinning in the air.
Once the car is back on the ground, the car rolls like it's in neutral.
Do you think it may be the motor has gone? It the esc is doing everything i ask of it in terms of programming. It's just the motor only seems to be able to do it when the wheel are off the ground.
I compared it to my touring car when in the ait and the brakes do seem a bit sharper on there than my pan car.
This is necessary on the Hobbywing ESCs I own.
Make sure your radio is set to have maximum braking strength by ensuring the radio is calibrated to the ESC with both full throttle and full brake set to 100%. Then turn down your braking strength as appropriate so the rear end doesn't break loose when you use push brake.
Bear in mind that even with these settings, brakes will still be very weak. good luck.
I have the EPA on my transmitter set to 150% which is the max both before and after calibrating. I calibrated as it said to in the manual such as reversing the throttle direct. I tried it without reversing. I tried calibrating the esc with a variety of epa settings but same still nothing.
At the moment I have drag brake force at 100%, brake force at 100%, reverse force at 100% - even though I'm running forward and brake, initial brake force is set at 40% which is the max. And still the car rolls like it's in neutral on the ground.
Is it possible that the motor can be worn out?
One final question - how fast is the car rolling when you engage the brakes? If you're not moving fast enough, you won't generate much in the way of braking force.
Regardless of whatever method finally yields a positive result, the brakes will always be weak using this ESC.
Okay thanks for your help guys, I just have a feeling the motor is a bit worn, it's not exactly new.
Luckily this esc and motor are just temps whilst I wait for my speed passion pro to get fixed under warranty and my other 4.5 Novak motor is over the limit for the Hobbywing esc I have.
no-run runs gearing that tall even in stock blinky.
What's your rollout?
