Old 11-02-2005, 10:06 PM   #16
Retard's Avatar
imo hako irons are way too expendsive..goot tq-95 able to do a decent job and way cheaper.
Retard is offline   Reply With Quote
Old 11-02-2005, 10:15 PM   #17
Randy Caster's Avatar
Trader Rating: 45 (100%+)
The soldering iron is one of your most important tools for racing. If you are willing to spend the cash on the good packs you should at least have a good iron to solder them together with. I use the Weller WESD51 and have had it for a couple years, works really well. Deans solder is good, but find a 63/37 blend solder and it will make life easier, melts at a lower temp and dries much faster than 60/40.
Old 11-03-2005, 12:25 AM   #18
PitCrew's Avatar
Originally Posted by Maxx
So i guess a 40 watt iron is useless then? Thats what i just picked up from radio shack. Don't laugh i am just getting into electric, I usually run nitro but am sick if having to wait till spring to run again.
That iron with the small tip will probably cause more damage to cells than it will do good for you.
Go to Sears or Lowes or something and get a Weller with the big tip. I think its 60 watts. Its only around $20 and it works perfectly for all RC stuff.
Maybe a bit too hot to do small things though, so don't use it on any circuit boards.
PitCrew is offline   Reply With Quote
Old 11-03-2005, 11:55 PM   #19
That big weller is really only good for batteries,it won't work in the small spaces we have in RC you'll end up melting everything around it.The Goot TQ-95 iron has a fairly small tip but it works like a big iron, plenty of heat.I was amazed at how well it works.
Hyper1 is offline   Reply With Quote
Solder / Solder Stand - Available Online? RC12 Electric On-Road 7 05-01-2008 09:20 AM
How do I get a Sticky Thread ? azcau R/C Tech Site Forum 5 07-31-2007 07:26 PM
Can we have an FAQ sticky???? BritRacer Painting, Designs, Graphics and Photography 1 11-29-2005 02:12 PM
Sticky? Platinum_Racing R/C Tech Site Forum 1 09-20-2005 05:50 PM
Sticky Track ? wallstreet Electric On-Road 18 06-11-2005 09:06 PM
SEO by vBSEO 3.5.0
