DJ Pro Module for Evo IV
anybody have any problems getting the pins into the wheel axel? (the little pin that holds the wheel hexes) it seems as if the 950 bearing will not fit flush into the hub carrier, thus the pin will not go into the wheel axel. when i finally did get it in, the pin rubs on the wheel axel!!
any help is appreciated
thanks
vic
thanks
vic
i had no problems whatsoever
I would try to reassemble the hub. It sounds like the bearing is just not pushed in far enough.
