Tire warmers, who's who and who's worth the money?
#17
SKYRC smaller size
#18
Only downside to the SkyRC is that you cannot use it as a car stand also.
Wonder why they designed it that way since all the competitors warmers are designed to be used as a car stand also.
#19
That's because you're supposed to attach it to the SkyRC Racingstar Power Supply, and that would lift your card 20cm off your setup board.
#20
#21
Only downside is all those danm wire.
An idea would be a wireless tirevarmer I would buy that
#22
I have a set of these. I put some thin foam on the top and my car sits just fine on them. Also, you can use the matching power supply to power a charger with this on your pit board and still charge your 2s pack at 13a which makes a convenient little package.
#23
Ah, OK. If you can "mod" it it would be alright
#24
What's the quality of the tire warming cups like across the different brands, SkyRC, Gforce, GT Power etc?
A bit pedantic but I've noticed most of them still have that shoddy heatshrink Frankenstein job on the connector end. Maybe they inherited this when they copied the Much More unit..
Xceed & GT Power have a tidy connector but are the warming cups junk?
#25
#26
I have repaired many cups. If you remove the clothing from the cup, there is a ty-wrap to secure the cable, cut it off.
Pull on the 4 small wires, one by one, one will be stretching. that one is broken.
#27
Thanks Roelof how do the heating red and black wires connect to the aluminium cup, are these soldered to a heating pad within the cup generally? I understand that the other two wires are for the temp probe which sits under the clothing of the cup.
#29
I believe they are mounted with a clamp to a small piece of a wire resistor but because the heater will not exceed 100 degrees you can solder them. I always strip the left over wires and solder them together with a shrinkwrap over it.
#30
Having now owned both the SKYRC and Muchmore tyre warmers I would recommend the extra and going for the Muchmore warmers.
Ok so you can repair the SKYRC cups when they break down however to me I don't want to have to do that routinely! I have enough work just maintaining my cars, motors, engines etc and do not have enough time to have to make random repairs to poor quality equipment nor do I want to have to buy replacement parts.
The Muchmore appears much higher quality and I haven't had a failure of the cups. The majority of the units in use at my local are now Muchmore with no failures. Many of the guys moved over from SKYRC due to the poor quality, Many of the units displays failed too - just displayed ######## on the displays.
The ability to run a 3s lipo inside the Muchmore warmers is a real plus particularly in winter where you can keep the tires hot right up while you wait in line to go on track for your run.
