Old 02-13-2015, 10:07 AM   #1
SagadSetup's Avatar
Trader Rating: 38 (100%+)
Default A touring car chassis that directly fit Tamiya bodies
Hello to all.
I have always been a fan of Tamiya bodies because of its detail.
My question is:
Is there a non Tamiya touring car chassis (eg: spec r-r2, detc410, tc6.2, arc, x-ray, yokomo bd7, etc.) that can directly fit Tamiya bodies by just simply following the "dimples" that come with it?
I am so bad at mounting bodies that I ruined several bodies because of poor alignment.
Thanks for your help in advance.
Are you right where you're supposed to be?
Think. Learn. Play. Plan. For soon you'll become.
SagadSetup is offline   Reply With Quote
Old 02-13-2015, 10:09 AM   #2
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
I don't think you should pic a race chassis just based on how well it lines up to Tamiya dimples on a body... Plus racing TC shells are better handling and lighter, unless you are running USGT or something.
Have you looked into magnetic body tools? They work great.
http://www.tqrcracing.com/shop/produ....asp?p_id=6954
Dan is offline   Reply With Quote
Old 02-13-2015, 10:14 AM   #3
Originally Posted by SagadSetup View Post
Hello to all.
My question is:
The Hobao/Ofna H4 claims the body mounts are a direct fit for Tamiya bodies.
Goals Achieved....Running at the End and Not Dead Last.
mooby64 is offline   Reply With Quote
Old 02-13-2015, 10:14 AM   #4
SteveM's Avatar
Trader Rating: 140 (100%+)
The quick answer is NO. If you are having issues mounting bodies, I suggest you try marking and/or drilling holes when the body is still clear. This makes life much easier once the shell is painted.
SteveM is offline   Reply With Quote
Old 02-13-2015, 10:16 AM   #5
SagadSetup's Avatar
I will look into the magnetic body tools.
It's more for building purposes and occasional racing. Tamiya TRF chassis are a bit expensive for my budget.
Old 02-13-2015, 10:56 AM   #6
b20btec's Avatar
The TB series is a great car if you're looking for occasional racing.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 02-13-2015, 12:58 PM   #7
wtcc's Avatar
I really suggest to drill the holes for the body mounts before applying the colours. I trim the body always when it is clear until it perfectly sits. Doing it like this it is easier and you have no disadvantage!
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 02-13-2015, 02:55 PM   #8
SagadSetup's Avatar
Thanks.
I currently own a TB04 Pro II. I haven't gotten around to running it yet because of the cold weather here...
Old 02-13-2015, 02:59 PM   #9
SagadSetup's Avatar
Noted sir. But I really am bad with mounting bodies as I said earlier. Fact is, I ruined several bodies because of poor mounting. I trimmed it as mentioned and mounted it, but, when I m done with the drilling it's askew.
Old 02-13-2015, 03:05 PM   #10
SagadSetup's Avatar
Another question would be is, What touring car chassis would be a great buy? One that doesn't need much hop-ups. Nice to build. Mainstream. With a flat plate CF chassis.
I am limited to 2 choices actually...
1. DETC410
2. TC6.2
Old 02-13-2015, 03:08 PM   #11
Hello to all.
My question is:
It's funny that you ask this. I just bought a Top Saber 1/10th scale car. I took a body from my 417x. And it was a direct fit. So if you buy a Top car. It's way cheaper than a TRF. Just as fast. And at least the front body post will fit. But you should be able to mount Tamiya bodues on any chassis as long as they are the same scale.
Juan Aveytia is offline   Reply With Quote
Old 02-13-2015, 03:16 PM   #12
SagadSetup's Avatar
Nice one sir Juan!
The front post is more than enough of a guide for me!
I will research for a Sabre chassis...
BTW, where can you buy these kits?
Old 02-13-2015, 04:46 PM   #13
hairless_ape's Avatar
1. DETC410
2. TC6.2
Why are you limited to those 2 choices? If price is your reasoning, there are better options that are even cheaper.
hairless_ape is offline   Reply With Quote
Old 02-13-2015, 04:48 PM   #14
SagadSetup's Avatar
Smile
Easy pay by Tower Hobbies...
What would be the other options sir?
Old 02-13-2015, 05:49 PM   #15
Off the top of my head...
3Racing Sakura Ultimate 2014
Spec-R R2
Team C TC10
The Sakura Ultimate and R2 are about $280-300 shipped, the TC10 is $250. All fully upgraded out of the box.
All 3 also have "sport" versions (less aluminum parts) of those cars. Team C & 3racing are $100 and Spec-R is about $120.
