STRANGE ISSUES; need opinion's >
Old 01-31-2015, 07:18 PM
Default STRANGE ISSUES; need opinion's
so i have a 3 racing D3 drift car with a hobby wing EZ Run 60A 9t brush-less motor system. my controller and receiver is a spektrum DX3c with the SR301 receiver.
my issue i am having is my car is really jittery (almost like there is interference) . when i try to go forward, full throttle from stopped. it is so laggy and jittery that it takes 3-4 seconds for the wheels to spin. once they do then they go fine but every time i let off i have that lag to get back into power..
also it WILL NOT go into reverse.
ive tried re programming ESC, tried re binding the controller, tried new battery's, reset controller to default setting to make sure there was no funky adjustments screwing with it.
before i just go spending money to try and fix the issue i just want to know if anyone has had this issue? an dis it my ESC, motor or receiver?
thank you in advance for any input.
tormaschy15 is offline
Old 01-31-2015, 08:00 PM
Geezatec's Avatar
rebind TX & rx w/o Steering and ESC connected. Then recalibrate ESC & RX. Make sure your Batteries are fully charged
Geezatec is offline
Old 01-31-2015, 08:05 PM
Two things to check, first if it is a sensor based system check the sensor lead, failing that have you ever plugged the battery in backwards as you may have an issue with the mosfet H-Bridge.
B.C.Ninja is offline
Old 01-31-2015, 08:56 PM
locked's Avatar
It's an EZ-run. Those are sensorless. And prone to some cogging, but this sounds excessive.
My first thought was that it might be overgeared, but being a drift car, it shouldn't take much effort to get the wheels spinning. tormaschy15, what size of spur and pinion are you using? How free is the driveline? Any bad bearings or anything else causing extra resistance?
Perhaps one of the 3 motor wires is not making a good connection. Bad soldering job or if it connects with bullet connectors that aren't making a solid connection, that could certainly cause some bad cogging. Having no reverse (assuming it's definitely set to that mode) could indicate a bad ESC. I would double check that all 3 motor phase wires are making a good connection though.
locked is offline
Old 01-31-2015, 09:16 PM
Connect a glitch capacitor to the receiver....
bertrandsv87 is offline
Old 01-31-2015, 10:55 PM
Geezatec's Avatar
What size pinion you using? You call it jittery, I call it cogging.
Geezatec is offline
Old 02-01-2015, 12:16 AM
Give a Glitch-Buster a try.
mooby64 is offline
Old 02-02-2015, 01:37 PM
Geezatec's Avatar
You probably purchased caps for it. Have to start from beginning. Binding you TX & RX. Set you TX trims at 12o'clock position, and EPA at 100%. Anything over 100% a waste. 3rd and last Recalibration of RX & ESc.
If you mess up from procedure Start beginning. Make sure the ESC confirms the setting by Audical beep or LED. .By this time you'd find that its running fine. Last but not least, install your program card to set up your reverse..
I agree with Locked, you maybe overgeared with pinion gear. drop it several teeth. Cogging if you help car by pushing car it'll run. Brushless motors are sensitive.
Geezatec is offline
Old 02-02-2015, 01:53 PM
Suspended
Trader Rating: 76 (100%+)
I call it Spektrum.
They are the worst with interference.
Metalsoft is offline
Old 02-02-2015, 05:56 PM
I forgot to mention that you might need to crank up your Esc minimum drive to max settings, or move your TX forward trim up a bit....
