Old 10-02-2005, 09:03 PM   #1
Unhappy Duratrax IntelliPeak Mini Pulse Charger
I have finally finished building my TA05 car but I am having a problem with the charger I bought (Duratrax IntelliPeak Mini Pulse DTXP4109 DC Onlywww.duratrax.com ). When I connect the charger to the power supply the status light illuminates and The charger beeps. When I connect battery the charge mode lights do not illuminate as per the instructions. When I press the mode select button nothing happens. Holding the button in for 3 seconds does nothing.
After reading the instructions again I noticed that a bettery with less than 3 Volts will trickle charge with only the status light on. As it was a brand new battery I thought that might be possible so I left it running for 30 hours (100 mAh trickle charge - 3000 mAh battery). The battery did charge and I was able to run the car. After the battery ran down I put it back on the charger only to have the same problem as before with the charger not responding.
Being new to RC I thought MAYBE the battery had discharged to below 3 volts so I left it on the charger for another 30 hours. This time I ran the car for about a minute and then put the battery on the charger again knowing that there was more than 3 volts in it. Same problem. Read throught the instruction book again. These sysmptoms appear to only happen when there is no battery connected however the battery is charging.
I have tried running the charger from both a 20 Amp power supply as well as from the car battery. It makes no difference.
Has anybody else experienced similar problems?
I don't want to return the charger for repair/exchange until I am positive I have tried everything. I would hate to be doing something stupid.
brettb76 is offline   Reply With Quote
Old 10-02-2005, 09:59 PM   #2
josh69162's Avatar
Send a message via AIM to josh69162
While I didn't have the specific problems you are having, I did notice a bad/not full charge when using the Duratrax chargers (the Ice being an exception). I borrowed my friend's Duratrax Intellipeak charger, and after acquiring a Novak Millenium, I noticed more punch, and more runtime. I hate to break it to you, but there is better ways to take care of your batteries. I've been down that road...
josh69162 is offline   Reply With Quote
Duratrax Intellipeak Mini Pulse Charger Arty_Harvy Electric On-Road 0 07-26-2008 06:42 PM
Ae XP2 Radiow/reciver & Duratrax Intellipeak Dc Mini Pulse charger xsxracing R/C Items: For Sale/Trade 9 10-23-2007 06:52 PM
Duratrax IntelliPeak DC Only Mini Pulse Charger & Towerhobbies charger$25.00(Shipped) xsxracing R/C Items: For Sale/Trade 0 10-13-2007 02:51 PM
Duratrax Intellipeak Pulse Charger lucky579 R/C Items: For Sale/Trade 1 10-15-2004 01:02 PM
Duratrax Intellipeak Pulse Charger solly R/C Items: For Sale/Trade 0 02-21-2003 02:24 PM
SEO by vBSEO 3.5.0
