Slick Diffs
Slick Diffs
Whats the best way to build the smoothest diffs possible?
what grease is best?
my car is a XXXS-G and the diffs a very smooth but smoother has got to be better !
need to do some work to you bearings too.
Carbid Diff Ball whit Ceramic Trust Bearing and Associated Diff Grease or the one from Xray!!
Later!
Later!
new washers, balls and some slick 50 One grease is the way to go
good grease and bearings is obviuos but what about the thrust washers ?some people say polish them others say 600 or 800 wet and dry which is better?
same there.. if ou can se or feel any wear on the balls/washers the change them..
