Old 01-14-2015, 06:31 AM   #1
Mitamiya's Avatar
Trader Rating: 14 (100%+)
Default ARS/ATS Is it faster?
For those of you racing with ARS or ATS, do you feel like it really works well or is it just a marketing gimmick? Any input would be appreciated.
MItamiya
Currently Racing
Offroad - Associated B5M Lite
Onroad - TRF 418 Samix VTA/TRF 419 USGT
Mitamiya is offline   Reply With Quote
Old 01-14-2015, 09:34 AM   #2
Trader Rating: 42 (100%+)
I feel it allows me to drive deeper into the corner on power without spinning as easily.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 01-14-2015, 10:19 AM   #3
Simmi's Avatar
It seems that ARS does not work on carpet. Have never seen a driver with ARS on carpet.
On asphalt is the Xray with ARS very very fast.
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 01-14-2015, 11:40 AM   #4
ATLASCOPCO's Avatar
Why dose it work on asphalt but not on carpet ??
ATLASCOPCO is offline   Reply With Quote
Old 01-14-2015, 11:46 AM   #5
syndr0me's Avatar
Trader Rating: 32 (100%+)
Makes my car (on carpet) feel broken. :-(
syndr0me is offline   Reply With Quote
Old 01-14-2015, 11:52 AM   #6
bdmpastx's Avatar
Most of the guys at our track (carpet) have taken it off.
bdmpastx is offline   Reply With Quote
Old 01-14-2015, 11:55 AM   #7
Odin544's Avatar
Trader Rating: 93 (100%+)
EA used it at IIC with good success. I've used it on high and medium traction carpet. Car was the best it's ever been using ARS on high traction. I didn't like it on medium traction but didn't play with it too much then. Was also using the TT aluminum chassis. It definitely makes the car feel and drive different.
I do find it funny that some people raved about the same thing on the awesomatix but then say how it doesn't work on an Xray. It's another option that hasn't been explored as much as other options. Some will like it, some wont.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 01-14-2015, 12:44 PM   #8
CristianTabush's Avatar
Except for the fastest guy here
I like it. It is challenging to set-up, but good once it gets going.
One issue that I found is that the ARS makes the rear really narrow on the XRAY, so I have found that adding shims to widen track width between the wheel and the hex helps make the car much better. The car seems to just roll too much when set up very narrow.
Personally I have it set up to where it has close to Zero toe gain/loss. I like it because I can set my car to have exact rear toe and I can also use fine increments of it. However the Toe gain/loss made the car inconsistent. I set the pills at max width RF and 0.5 in on the RR. The rest of the toe I add with the turnbuckles. I go between 2.25 and 2.5 degrees of rear toe most of the time and also have a 0.5mm shim raising the RR and RF Suspension mounts from the center pill position. (Also helps control rear toe)
Now does it make the car better or worse? Both. Set up correctly is a nice addition that can simplify the rear end adjustment and unlock unlimited rear toe settings. When set up wrong, as Syndrome stated, can make the car feel like its broken.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 01-14-2015, 01:25 PM   #9
Roelof's Avatar
Send a message via ICQ to Roelof
BMT had it back in 1994 and I did love it. It was continued on the BMT 95R but it was gone on the 1996 Pantera. Serpent had it on their 710 or 720 but with the follow up car it was gone and never came back.
So we will see if it will stay ar Xray....
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 01-14-2015, 01:34 PM   #10
Adding toe at the hinges or hub carrier have different effects too so while it may make things complicated, it is a welcome setup imo.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 01-14-2015, 04:58 PM   #11
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
ATS works well on low to high traction asphalt. Havent tried it yet on carpet. Will let you know on Feb 7th.
Josh-n-ya is offline   Reply With Quote
Old 01-15-2015, 02:30 AM   #12
Josh-n-ya, could you please post your ATS setting for low traction, technical track for ARC?
Smashrc is offline   Reply With Quote
Old 01-15-2015, 05:56 PM   #13
You coming down to Chino ? Carpet is not high grip there at Tq.
John B.
[RC America][ VP FUEL][SRC][FG Supply][Maclan Racing][Xpert Servos][LRP][Heli Direct][LionArtPrints]
DOTHOPPER is offline   Reply With Quote
Old 01-15-2015, 06:04 PM   #14
Josh-n-ya's Avatar
I will soon
No. We are waiting for a carpet track to get going up here in Stockton.
Old 01-15-2015, 06:51 PM   #15
All the setups I have seen for the Awesomatix no one has mentioned the use of this option, unless the guy at your track are using it. I have tried it on both carpet and asphalt and could not get the car to feel consistent. I think this option takes the right track conditions to work, but it is not a game changer for any chassis it is used on. Bottom line is that if you feel it works for you then use it.
Patrick
XCELL is offline   Reply With Quote
