Old 01-13-2015, 09:38 PM   #1
Default Sweep V2 F1 tires
Ok........someone explain to me how the heck you get Sweep tires to fit on Tamiya F104 wheels........it seems as tho the inserts are too big to fit........I have been working on 1. Yes ONE for about an hour trying to get it mounted and seated on the rim......am I missing something or is this normal.......help?
Shaun Barron.
Big and Important Titles
2 lines of sponsors!
Cuz Big and Important Titles and 2 lines of sponsors are way cool
Shaun B22 is offline   Reply With Quote
Old 01-14-2015, 02:00 AM   #2
There are 2 types of F104 rims...the flat and the ridged rims. Originally the flat rims were for foam tires and the ridged rims for rubber tires. But Pit Shimizu came out with their rubber tires that mount to the foam rims and the new TCS tire is a Shimizu tire. But looking at the pics on Sweep's website it looks like they take the original ridged rims for rubber tires. So you have to make sure you are using the right rims.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 01-14-2015, 09:00 AM   #3
yes I have the correct wheels........and I have used Pits on Exotek wheels as well......with F1 becoming more popular in my area we are doing R&D on tires.....Pits, RIDE, Sweep and I am going to order a set of GRP. to clear up the question......mounting Sweep tires on Tamiya wheels should it be VERY hard to get the tire wrapped around the wheel and seated on the bead. it seams to me as tho the foam insert is too big......I have never mounted a set of Tamiya tires so I am not sure if it is normal.......the Pit Shimizu tires mounted perfectly to the Exotek wheels so that is what I was expecting with the Sweeps.
Shaun Barron.
Old 01-14-2015, 09:34 AM   #4
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The Sweep Tires are overstuffed. They need either a fitted insert or to cut the insert at 45* like offroad inserts. I have a couple sets of V1s and they might as well be drift tires.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 01-14-2015, 10:01 AM   #5
Evo 13's Avatar
Okay, so its not just me. There really is a steep learning curve when it comes to these F1 tires/wheels.
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 01-14-2015, 01:49 PM   #6
is there a company that makes molded Closed cell inserts for F1 tires? I would love to get my hands on some......I have been using the Proline Closed Cell inserts for offroad for a while now and I would never go back to open cell again.
what about just using Tamiya inserts? Is it the tire compound or insert that makes Pit Shimizus so good?
Shaun Barron.
Old 01-14-2015, 03:03 PM   #7
The Pit tires are great once mounted. The TCS tires are made by Pit Shimizu, 571/572.
Old 01-14-2015, 11:45 PM   #8
The sweep website says that for V1 inserts (grey?) to trim down 1mm. However this was fixed with the white v2 inserts.
The v1 tires were rubbish, the v2 tires are meant to be ok. Realistically though Ride or Pit tires over ok tires any day.
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 01-14-2015, 11:50 PM   #9
Funny.....I got V2 tires with grey foam inserts with sticky on one side.......odd! I am going to trim the inserts and see what happens.......if that don't work I will just get Tamiya inserts
Shaun Barron.
