Old 01-10-2015, 02:34 PM   #1
blf
Default Pinion Range Suggestion
Hi Guys --- finishing my first TC, not new to RC, but wanted to see what pinions are appropriate for a 540 motor and the stock spur on my Tamiya TB-06?
What is the pitch and even a particular recommended brand you guys would suggest? What tooth range will give me decent "coverage" in most situations?
Thanks, Im coming from 550 motors and MOD 1 5mm shaft pinions so I'm new to the gearing on these ...... thanks
Wanting to use with either a 13.5 or 17.5 motor BTW
blf is offline   Reply With Quote
Old 01-10-2015, 02:54 PM   #2
blf
I'm seeing that its the same spur as the TB04 so its 06 mod? Can someone confirm and would 25-32t be a decent range to test with from the get go?
Old 01-11-2015, 12:23 PM   #3
blf
Bump ----- anybody?
I'm surprised no-one can help on this one - I was going to order this type:
http://www.tqrcracing.com/shop/produ....asp?p_id=7313
& just wanted to confirm these are appropriate for 540 motor with the stock 66t spur gear?
