21.5 High trq or high RPM motor for Formula 1? First time driving direct drive too.
21.5 High trq or high RPM motor for Formula 1? First time driving direct drive.
Also which motor do you recommend for a LRP Flow esc?
Chassis is Tamiya TRF101.
Thanks!
Thanks!
I prefer high rpm, last thing a F1 needs is more punch.
Just depends how you gear it. The trackstar 21.5 is known to be a torque motor, but if geared at 80mm/rev or higher, it certainly becomes very easy to drive and with good top speed. If you geared it at say 70mm/rev it would be very hard to drive.
The diffs make a huge difference in 1/12 so probably will in F1 as well.
