Old 09-28-2005, 02:01 PM   #1
Default Changing Motor Bearing on Spec 19 Turn Legal?
The bearings on my dynasty 19t has gone bad and this is already the 2nd one with the same problem. Just wanted to know if changing the bearings on a Spec 19 Turn motor is legal or not...
Thanks guys!
RC Robin Hood is offline   Reply With Quote
Old 09-28-2005, 02:14 PM   #2
EddieO's Avatar
R/C Tech Charter Subscriber
It doesn't really say in the rules you can, nor does it say you cannot. I would say if you replaced them with regular bearings you would not have an issue....as its just a bearing and really there is no way to coax any additional power out of it.
Later EddieO
EddieO is offline   Reply With Quote
Old 09-28-2005, 02:24 PM   #3
raving-monkey's Avatar
Send a message via MSN to raving-monkey
yes it should be legal....although you should have to replace them with identical units to make it not a hybrid (yes some associations are that piccy!) but i guess you could replace them with what ever and they wouldnt even know...as it won't do much for your motor.
raving-monkey is offline   Reply With Quote
Old 09-29-2005, 09:26 AM   #4
I recently upgrade my FK05 to ceramics and noticed the transmission was much smoother. So I'm going to try these APS ceramic ones and see how they do.
APS Ceramic Ball Bearing Set for MOTOR, 2 pcs. (Top Grade w/Stainless Steel Rings) APS87020
what is the best 19 turn motor (not spec) Apple Electric On-Road 46 02-03-2006 11:27 AM
Gearing of a 19 turn spec motor pcmlc Electric On-Road 15 05-08-2005 11:39 AM
Reedy Quad Mag 19 Turn Motor, Not ROAR Legal?! Cain Electric On-Road 59 01-07-2005 11:54 AM
Reedy 19-Turn Quad Mag Spec Motor Hebiki Electric On-Road 14 12-28-2004 02:19 PM
BRCA Legal 19 Turn Spec Motors Mr. MR4 Electric On-Road 4 05-16-2003 06:46 AM
SEO by vBSEO 3.5.0
