Old 12-28-2014, 07:59 AM   #1
Default New damper set for 1:10 Touring cars
Hello Guys
I am planning to make the new air damper for 1:10 Touring cars and I'd like to know how many would like to have a damper set, in order to optimise the serie to make.
Please write which car you have and specify the damper length fully extended from center of mounting holes (eye to eye).
Thanks everyone!
estefano is offline   Reply With Quote
Old 12-28-2014, 10:41 PM   #2
It's a Damper of a brand new generation. It hasn't oil in it and is without the coil spring, just air pressure, easy to maintain, very strong contruction and eco-friendly.
Old 12-29-2014, 04:34 AM   #3
theproffesor's Avatar
Trader Rating: 57 (100%+)
How would one adjust such a system? The current shock design allows for tons of adjustability; oil viscosity, piston hole size, spring rate, and pre-load to adjust ride hight. Maybe you should post up yohr design or at least explain how you plan to address tuning with these shocks.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 12-29-2014, 07:24 AM   #4
The pressure increases "irregular", during the compression of damper, it gets harder. You just adjust the volume size of damper and put the right pressure.
don't you think it's time for a new damper, like the brushless motor and LiPo came out to improve our hobby?!?
Old 12-29-2014, 07:34 AM   #5
Metalsoft's Avatar
Trader Rating: 69 (100%+)
I wouldn't. He might be on to something no doubt. You could adjust them very similar to how you adjust the oil filled ones.
If it works correctly, it might even be better. Less messy and a pain at the least.
Most people are scared of little changes, I for one like innovative ideas.
Good luck to you. Don't worry about the VTA guys, their cars aren't fast enough to feel changes anyway....
Tamiya TB03 USGT - Custom Carbon fiber Chassis - Magoo Racing Inc....
Metalsoft is offline   Reply With Quote
Old 12-29-2014, 07:43 AM   #6
Im all for changes, just would like to understand the physics behind the part before pledging any $$$.
Old 12-29-2014, 08:34 AM   #7
b20btec's Avatar
I'll measure some shocks and pm you the length.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 12-29-2014, 09:00 AM   #8
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
There has never been to my recollection, an air damper in motor racing, that has surpassed the performance of spring oil systems
In the interest of weight savings, much work has been, and is still ongoing in this area
Good luck to you
Will be looking in on this discussion with much interest
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-29-2014, 09:17 AM   #9
samnelso's Avatar
Most air shocks that I know of are a combo of oil and nitrogen. Just air alone won't get you there unless you're just looking for an air spring.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 12-29-2014, 09:45 AM   #10
patorz31's Avatar
I have run Nitrogen Sprung shock assemblies on my Full Scale off road stuff before (Ultra 4 type stuff) and have always come back to conventional Coil Spring coil overs. The "Air Shocks" are lighter but the spring rate changes through the stroke at a very steep curve. It makes it harder to setup then a linear steel coil spring. Also the fact that a broken "Air" Spring means that that particular corner of the vehicle is now riding on the hydraulic bump stop is the reason for going back to coils. If I break a coil spring (only ever broken one in 12 years of racing full scale and only broke 1 and half turns off) whats left still holds that corner off of he ground.
The Coils are a very old technology that is very proven in the field of Motorsports. Sometimes I think simple is better.
I look forward to seeing these in person and would order a set just to see how the work.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
SCHUMACHER RACING Canada,TEAM POWERS, Mon-Tech,Sanwa
patorz31 is online now   Reply With Quote
Old 12-29-2014, 10:48 AM   #11
I'm all for innovation and different thinking but this is essentially like replacing the shocks/struts/springs on a real car with air bags. Yes you can alter the pressure in them but you can't control damping ability without also effectively changing the air spring rate. It's primarily only used as an accessory to a standard suspension to aid in holding the rear end of a vehicle up temporarily while hauling something heavy or by those with low riders who want a certain look. It is never used as a performance modification and rightly so.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 12-29-2014, 11:07 AM   #12
Trader Rating: 1069 (100%+)
compressed air also changes pressure significantly to changes in temperature. Not saying its a bad idea, just another thing to think about
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 12-29-2014, 12:38 PM   #13
Chaz955i's Avatar
No reason whatsoever that damping and springing have to be tied together. This can be accomplished by separating the two functions into separate chambers. Factory supercross bikes are almost all using air sprung forks and KTM was experimenting with an air shock. Using air is not limited to lowriders and load levelers for trucks. A big issue is the amount of seal drag since tolerances have to be very tight in order to keep the air in. Negative springs help but this is a level of complexity that I'd rather avoid with my toy cars.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 12-29-2014, 04:01 PM   #14
bigfatslob's Avatar
I would probably give them a try, I need 50mm & 55mm sizes. Need more info, specifications and price shipped to USA. Repair and or replacement parts ????
Vintage is the way we roll : XXXS & TT01
bigfatslob is offline   Reply With Quote
Old 12-29-2014, 07:40 PM   #15
Ivan Dickson's Avatar
Trader Rating: 11 (92%+)
Can't knock it to you try it...I would love to see some feedback
after testing.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
