Old 12-26-2014, 12:30 PM   #1
longuylander's Avatar
Default The Death of a Battery?
I went to charge up one of my 2S lipo batteries for a fun romp with my old Tamiya TA02 rally car. When I connected it to the charger (a cheap Duratrax Onyx 150), it started beeping wildly, indicating the battery was not charging. I tested the voltage of the battery to find it was at 4.9V!!
So there are two questions here:
1. What could have caused the battery's voltage to drop so low? It had been stored at room temperature for around two months and around 7.2V.
2. Is there any way to revive the battery? I tried charging it at 1A, 3A, and 5A with no success. It's not puffed. Would attempting a charge without the balancer plug work?
longuylander is offline   Reply With Quote
Old 12-26-2014, 12:57 PM   #2
scirocco14's Avatar
I've had some success reviving lipo batteries that have gone too low in voltage by charging them SLOWLY on a NiCd or NiMh setting. WATCH THEM CAREFULLY while you do this, in case the battery has an internal short.
Once the voltage is high enough for the balance charge to work, switch over.
Good luck!
Mark
Mark C. USVTA #115 TC4 & TC5, USGT #115 Xray T4 '13
USVTA-F1 #115 F103.5 & F1R3
Tamiya M05 M06
Bush River RC, The RUG at King, Ho B Max Raceway
scirocco14 is offline   Reply With Quote
Old 12-26-2014, 01:12 PM   #3
SWTour's Avatar
can you check the voltage on each 1/2 of the balance? if you can you may find that 1/2 of your pack (1cell) is dead or extremely out of balance -
If so - try charging that 1/2 or that cell to bring it up to the other one.
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 12-26-2014, 05:29 PM   #4
Skiddins's Avatar
Stick the battery in strong salt water solution to completely discharge it, then recycle the battery when completely dead.
Buy a new decent battery.
Having gone below voltage the pack will almost certainly have suffered some internal damage, and if it self discharged that quickly when not connected to anything it was a dodgy pack already.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-26-2014, 05:40 PM   #5
Super Moderator
7.2 volts is too low of a storage voltage for a 2S, at least for an extended time. The pack was essentially fully discharged, not much margin for error/slight self discharge.
A typical resting voltage vs capacity table, based on discharging at 1C to 3V. Of course this will vary some by cell but most tests I have seen over the years are fairly close.
4.20v = 100%
4.03v = 76%
3.86v = 52%
3.83v = 42%
3.79v = 30%
3.70v = 11%
3.6?v = 0%
3.8 to 3.85V per cell, or 7.6 to 7.7V for a 2S, is a much more reliable storage voltage best I can tell.
Dave H is offline   Reply With Quote
Old 12-26-2014, 08:56 PM   #6
D.a.v.e's Avatar
Toss the pack. It's not worth messing with. You might get it to work but there is something wrong with it. Think of it as a time bomb you caught early.
I have tried bringing one back and it went up in flames about 6 hrs after I thought I had saved it. Luckily it was in a corningware bowl in the middle of my garage so no real damage other then smoke.
D.a.v.e is offline   Reply With Quote
Old 12-26-2014, 09:16 PM   #7
never do the salt water method instead plug it into a low amp light bulb till completely dead then use salt water
stampede 2wd hobbyking x car 120a esc, neewer 550 4 pole 4300kv motor,turnigy nano tech shorty 2s lipo 4200mah 65c, random crappy rtr controller,soon to be turnigy 15.5kg/cm .16s servo-brushless tmaxx turnigy 160a sensorless esc, turnigy 4 pole 1/8 scale 2100kv motor, some brand lipo from hobbyking 4s 4000mah 30-40c, turnigy 12.5kg/cm servo same controller and receiver, brushless emaxx tranny, hpi sprint 69 mustang body
rc car freak is offline   Reply With Quote
Old 12-27-2014, 03:22 AM   #8
Skiddins's Avatar
No, the salt water will discharge it so it's completely dead.
It also does it very slowly, reducing the chances of a fault trying to cause a fire etc.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 12-27-2014, 12:41 PM   #9
Thanks for the advice all; I think I'm going to play it safe and not try to charge the battery with an NiMH charger. I'd still love to know why it drained though. Perhaps it was too discharged (I had always heard around 7.4V was a good storage value), or perhaps it was just a poorly constructed battery.
Old 12-27-2014, 05:35 PM   #10
Geezatec's Avatar
Gunna ask you, What lipo charger you use? Does it use a storage charger and individual cell voltage? Abalance charger? Is it a combination lipo & NiMh charger?
1) Probably when you discharged it by running it down, and didn't put a storage charge on it.
2) Have to know what charger you use. Then I'll though it with you.
Geezatec is offline   Reply With Quote
Old 12-27-2014, 08:15 PM   #11
Super Moderator
Unless the salt water corrodes the connections before the cells are discharged, which several guys have experienced. If the connections are good the light bulb method seems to work well. Using a safe location is wise with either method I think.
Old 12-27-2014, 09:09 PM   #12
Geezatec's Avatar
With the Onyx 150 its not good enough. You need a charger that does both lipo's and NiMh, function to read cell voltage, Balance charger, and to storage charging. Storage charging charges 1/3-1/2amps in lipo's for storage. Full amps for storage will weaken the lipo's. There is a way to revive lipo's from low voltage cell errors. If lipo's are not puffed out you can revive.
Old 12-28-2014, 02:12 AM   #13
alcyon's Avatar
Charging with nimh mode works. You cheat the charger into thinking its a nimh. You monitor the voltage as its charging. Set it to 6cell nimh. As soon as voltage rises to 6.3v you are all set. Stop the charger n switch to lipo mode. It works trust me.
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 12-28-2014, 03:01 AM   #14
ShadowAu's Avatar
Did exactly this, this past weekend, and battery seems to be fine now...
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 12-28-2014, 06:35 AM   #15
O.k., I went back on what I said earlier and busted out the old NiMH charger. Set on 0.8A, I hooked up the battery. When it started charging, the voltage reading was already 6.85V (I'm not quite sure how that's possible... it definitely read 4.9V prior when hooked up to a Speed Passion ESC). After less than two minutes and 25mAh of charging, the voltage read 7.05V. I hooked the battery back up to the lipo charger, and it started charging, which it is currently doing.
I'll comment when it finishes, if it finishes, and if it doesn't puff or burst into flames. Well, I'll post if it does burst into flames too, but only after I put the fire out.
