Old 09-26-2005, 08:35 PM   #1
Default Question on Gear Ratios
So this year I made the step to Carpet and have some concerns on gear ratios. I purchased an Xray FK 04 kit and plan to run a Fantom 19t Quad mag motor. The current spur I have on the car is 99. I am running Jaco Double Pink rear tires and Jaco Double Pink Orange tires up front.
I am trying to make a rollout chart but have no idea what pinion I should use and the proper ratio I should aim for.
If it helps I am running Ib 3800 batteries.
Thanks for your help.
Flash-R.C. is offline   Reply With Quote
Old 09-27-2005, 05:58 PM   #2
just go here ... www.gearchart.com . There you can input all the info you have and it will give you just what your looking for ....
Mark Barden .
mb racer is offline   Reply With Quote
Old 10-25-2005, 10:48 PM   #3
newera152's Avatar
I used it, it works
newera152 is offline   Reply With Quote
Old 10-26-2005, 03:08 AM   #4
zax's Avatar
Default ..
i am using 540 mabuchi motor..my gearing is 4.97..is it acceptable?
zax is offline   Reply With Quote
Gear Ratios/ Spur Gear Sparky7B Rookie Zone 2 02-26-2008 09:03 PM
Gear ratios N15M0 Rookie Zone 14 10-06-2005 04:36 PM
help with gear ratios! moot Electric On-Road 1 03-15-2005 01:43 AM
tc3 gear ratios? kh15 Electric On-Road 3 07-24-2004 01:13 AM
Gear Ratios.... Rain Rookie Zone 4 11-14-2003 06:23 PM
SEO by vBSEO 3.5.0
