Old 01-06-2015, 01:20 PM   #16
Paco1001's Avatar
I have been using a Spektrum h5020g for 2 years now. Works great, very fast. Little less cash than the 9650 as well.
Paco1001 is offline   Reply With Quote
Old 08-13-2015, 02:28 PM   #17
Romac's Avatar
Hi everyone.
I just picked up a new CRC Xti-WC and am quite pumped to run it. In the manual it shows some servo options and mounting suggestions, e.g. JR 3650, 3717HV which you have to cut off one set of side tabs and Airtonics 94761 where you can mount it directly to the chassis (using hardware).
I currently have a Futaba S9602 which I have used in the last couple of 1/12 cars. Not a big fan of cutting servo tabs.
Those of you running this car what are you using for a servo? How is the centering on the Airtonics, are there other good servo's that can be mounted w/o cutting them?
TIA
Rob
Romac is offline   Reply With Quote
Old 08-13-2015, 03:58 PM   #18
wingracer's Avatar
Trader Rating: 23 (100%+)
I'm using a JR 3650 shoe goo'd down behind the arms (not between) with no ears cut. I like this set-up because it leaves the option open for going with a long arm set-up on the front end.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
