Old 12-18-2014, 02:32 PM   #1
Default Need advice
Hi all,
I'm new to RCTECH and very excited to get into the world of RC racing! I recently purchased a second hand X-Ray T4 that I'm building and need some advice on what ESC to use. It has a Team Orion 21.5t motor which suits because I'm going to be running Sportmans 21.5t class but I'm unsure on which ESC to purchase. It will be blinky mode, do I spend a little more and get a good ESC or do I just buy a cheaper ESC.
There are so many choices out there! Please advise a good brand!
can someone please help?
___________________________
Cheers
Kegson is offline   Reply With Quote
Old 12-18-2014, 02:36 PM   #2
if they run blinky then get a hobby wing justock. great esc for the money. comes with a fan too. about $50 usd. or if you want higher end i would reccomend a lrp flow esc. great esc very programmable and pretty bullet proof. been using mine for a year with no issues.
dragonracing is offline   Reply With Quote
Old 12-18-2014, 02:38 PM   #3
longuylander's Avatar
Hobbywing would work well for blinky, as would a Speed Passion Club Racer. Also around $50.
longuylander is offline   Reply With Quote
Old 12-18-2014, 02:39 PM   #4
Thanks for replying! I was thinking if I enjoy it I may want to progress to 13.5t so a higher end ESC might be a better choice.
I will check both out! thanks for your help...
Cheers
Old 12-18-2014, 02:40 PM   #5
Another question, do they come ready for blinky or do I have to purchase the program card?
Cheers
Old 12-18-2014, 02:42 PM   #6
Trader Rating: 44 (100%+)
The justock is only blinky.
Aaron Moore
Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 12-18-2014, 02:55 PM   #7
The Club Racer can only run in blinky mode. All that can be changed through the programming card is brake strength, lipo cutoff, and throttle mapping. Essentially, if you ever plan on moving up past stock classes, you'll want a different esc. Their Reventon S or R can be switched to mod and boost modes, but you'll need the programming card and the computer software. They too can be found for relatively cheap.
Old 12-18-2014, 03:00 PM   #8
Thanks for the advice, I'll have a look at the speed passion, could be a good option!
Cheers
Old 12-18-2014, 03:09 PM   #9
the lrp flow can be changed in the esc itself without a program card from blinky to non blinky.
Old 12-18-2014, 03:25 PM   #10
Thanks for all your help, both the LRP and Speed Passion look good, I just found that Team Orion have a stock ESC. Would that suit the motor better with them both being Orion?
Cheers
Old 12-18-2014, 03:28 PM   #11
Racermac73's Avatar
Probably won't be a popular answer in here but I have found the team Orion speedo to make more torque than anything else including the hobbywing, lrp and tekin. Not very popular in the states but one of the biggest everywhere else
TEAM SCREAM, McFACTORY, TQ WIRE, 360 RACEWAY, XENON-USA.COM, SANWA, DESOTO RACING, JFT TIRES, HOBBYWING, EAM, DESTINY USA, DRIVE RC, TOP USA
Racermac73 is offline   Reply With Quote
Old 12-18-2014, 03:49 PM   #12
RotorTruck's Avatar
For $78 the Justock and LCD Programming box is tough to beat for blinky.
RotorTruck is offline   Reply With Quote
Old 12-18-2014, 04:42 PM   #13
Hobbyking X car 120a. About $45 shipped with the USB dongle. Download hobbywing blinky software. You can get the $10 hobbywing programming card for at track changes.
This will allow you to go all the way up to mod if you choose.
2uzferunner03 is offline   Reply With Quote
Old 12-18-2014, 07:51 PM   #14
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
Get in touch with Walters Hobbies at Fairfield area (Sydney) & they can help you with all you need
Brokin Racing is offline   Reply With Quote
Old 12-19-2014, 03:28 AM   #15
oreo's Avatar
Greetings. If your funds can permit, you can go with the higher priced esc's. Many around the forums have been contented with Hobbywing/Hobbyking's esc's(see attached)- though i've not been able to get enough practice time with these, i'm happy with these cos' they're within my rc budget. The Hobbywing Justock Clubspec(pictured on right) is a decent fit in my 12th scale(onroad) with a shorty battery. This is a simple reason why i'd bought this esc. The two on the left are basically the same Turnigy XCar 120amp[the Xcar was shipped out of China] where the other was from BrushlessHobbies.com. These (3)are compatible with the same program box.Anyways , goodluck with your choice.
Rc 10L (x6)
(.......in 2010, I jus' may get to run one.)-Irrgang Racing Service;TeamCRP. R.I.P. Billy 105
oreo is offline   Reply With Quote
