Like Tree5Likes
Old 03-14-2017, 10:59 AM   #631
Anybody put shims underneath the lower suspension arm mounts? Installed the new lower suspension arms yesterday and they seem to sit much lower on the chassis than the old ones.
Regards, Gero
Gero is offline   Reply With Quote
Old 03-14-2017, 12:13 PM   #632
CristianTabush's Avatar
You may want to use maybe like 1.0mm under the lower arm. You really want to have the same roll center as before.
CristianTabush is offline   Reply With Quote
Old 03-14-2017, 01:23 PM   #633
If thats your suggestion i will give
it a try.
Thanks, Gero
Old 06-08-2017, 03:40 AM   #634
LonnyJ1950's Avatar
Originally Posted by clint View Post
Hey guys do any of you have the assembly pictures AKA "manual" for the T2 ??
Pics on page 35 and page 38 help, but you are generally on your own.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 06-08-2017, 04:10 PM   #635
Jorge T's Avatar
It fits! Works Very smooth. 12R6/10F6 rear pivot.
Test and tune Saturday at Banana.
Thunderbunny and aracefan like this.
RSD MS
Jorge T is offline   Reply With Quote
Old 06-08-2017, 04:36 PM   #636
hanulec's Avatar
Trader Rating: 27 (100%+)
I expect we will see this a lot this winter
Antimullet likes this.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-10-2017, 01:23 AM   #637
LonnyJ1950's Avatar
Anybody got a good starting set up for low to medium bite asphalt. My kit came with gold front springs that seem awfully stiff.
Lonny
Old 07-10-2017, 06:14 AM   #638
Which version of the car and which front end is installed?
Old 07-10-2017, 09:59 AM   #639
chris moore's Avatar
Trader Rating: 87 (99%+)
How well did the new pivot work? Do you have the part number for the new pivot?
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 07-10-2017, 11:04 AM   #640
LonnyJ1950's Avatar
T2 with double a-arm front.
Lonny
Old 07-10-2017, 11:18 AM   #641
For front springs, I suggest using the Yokomo r12 black front springs. You should be able to find them at A Main.
For set up:
Front:
-2.0mm under knuckle, 0.5mm above. Rest of shims, use so that the upper arm and lower arm pivot balls don't bind on the eclip. I usually install 3 shims up top and the rest at the bottom
-0.3-0.5mm droop
-3.8-4.0 mm ride height
-3 degrees of caster
-1.5 deg of camber
-Kyosho 30,000 blue grease on tube
Rear:
-Kyosho 15,000 side tube lube
-RSD green side spring
-AE Gold Center Spring
-1.0mm pod droop
-30wt center shock.
-2mm under outside of side tubes
+2 mm wheelbase
4.0mm ride height
-170mm track width
-XRAY Side links
That should about cover it I think
Thunderbunny and LonnyJ1950 like this.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
Old 07-10-2017, 12:43 PM   #642
LonnyJ1950's Avatar
THANKS!
Lonny
