Like Tree5Likes
Old 10-22-2016, 03:56 PM   #571
idbdoug's Avatar
Trader Rating: 33 (100%+)
Great post Troy carter
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 10-27-2016, 12:28 PM   #572
Originally Posted by CristianTabush View Post
There are different options. The only one we have for a 12R5,with an aluminum chassis is the full conversion. This is part no: RR12T2
In this product, you have 2 options, complete conversion or complete kit. The conversion comes without tubes, diff, shock, linkages for the sides and the steering.
Both of them include the RSD Front end.
Christian
Is the aluminum chassis included with this conversion drilled for the old school Associated front end also or do you have to use the RSD front end?
Bubonic-X is offline   Reply With Quote
Old 10-27-2016, 12:35 PM   #573
CristianTabush's Avatar
It is not drilled for an old school front end. It has holes for the current AE front end or our own double a arm front suspension.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 10-27-2016, 01:55 PM   #574
So I have the 12r5.1 front arms those should work then if I choose to use them? Also in the pic of conversion kit I don't see any of the double a arm front end parts. Can you post a link to the online manual please
Old 10-27-2016, 02:22 PM   #575
Yes, you can use the AE 12R5 front end parts. You may be looking at the wrong conversion if you are not seeing the front end parts. The full T2 conversion kit is part no RR12T2. The 12R5/ RR12V2 conversion is part no: RSD1231 and it does not include the RSD Front end.
Old 10-27-2016, 03:36 PM   #576
I want to make sure Im getting the right conversion and the only conversion kit I see on your site that is close to the part number RSD1231 is part no: RSD1233 I cannot find RSD1231....
Old 11-05-2016, 09:18 AM   #577
How much is the front end separately, as I already have the t2 conversion (minus front end)?
shaggy1 is offline   Reply With Quote
Old 11-05-2016, 11:27 AM   #578
Front end is roughly $80.00 retail. If you need one, you can email me directly at the store.
Old 11-05-2016, 11:46 AM   #579
Jim Frahm's Avatar
Trader Rating: 68 (100%+)
Send a message via Yahoo to Jim Frahm
I had a chance to see this car in person at our local track; it is one sweet looking ride. Oh, and it's fast too. Nice work Cristian.
Serpent S411 ERYX, Reedy 25.5, FLOW
AE 12R5.2, Trinity 17.5, ORCA
Jim Frahm is offline   Reply With Quote
Old 11-05-2016, 11:59 AM   #580
Thanks for the compliment!
Old 11-05-2016, 03:02 PM   #581
Thanks Christian, will do
Old 11-06-2016, 06:20 AM   #582
landau's Avatar
The 2016 Winter On-road Series at the Banana!
Classes:
17.5 12th Scale
USGT
17.5 Sedan
Mod Sedan
25.5 F1
Nas class
Dates:
November 5th
November 12th
November 19th
November 26th
December 3rd
December 10th
December 17th
I attended 1st race yesterday 17.5/12th.
RR12T2 was pretty nice performance.
This car, I thought, is not neccesally rubber tyre, such as BSR controlled.
Tyre wear was flat also. I could use same tyre 5 packs(P1+Q3F1) from F41.0mm R41.5 to F40.3mm R40.9mm. After race, tyre surface keep flat.
Wheel: Yokomo/ Yellow
Cristian's Innovation, motor cooling fun, had well performance. Motor Temp approximately same each round, 43.4-44.3Centigrade.
I have never tested BSR tyre so far, but comparing CRC lilac, form tyre is not bad. Forward traction on form tyre was better than rubber. Steering was little bit nasty; first 2mini requires careful drive, last 2mini less initial response.
The only bad is upper arm. I have used Asso arm. This arm should exchange routinely.
Xenon is better, like as Cristian's T2.
Overall, I felt T2 had little bit advantage compare with others.
ESC: Tekin RS
Battery: Reedy6500(dead during race) or Trion7000(over 200 packs), I have to buy new one.
Motor: TS V3
ratio: 53/76
ride hight: 3.2mm
Steering pretention: 0.8mm(at first, 4mm ride hight with free droop screw, and then adjust 3.2mm)
caster: 1.5/Right, 2.5/Left
camber: R0.3-0.5 L0.5-0.7 (F.E. Q1=R0.5L0.7,,,Q3 or Final=R0.3L0.5)
landau is offline   Reply With Quote
Old 11-06-2016, 04:18 PM   #583
How you guys change the ride height in the front with the double wishbone front axle?
By the preload of the front spring or by the change of shims on the top and bottom of the steering knuckle?
Regards, Gero
Gero is offline   Reply With Quote
Old 11-06-2016, 04:55 PM   #584
Trader Rating: 42 (100%+)
Regards, Gero
Two droop screws on the front top of the chassis just behind the bumper.
Super easy and quick.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 11-06-2016, 04:57 PM   #585
By pre-loading the spring on the A-Arm. Additionally, since most set-ups require very low droop settings, you may need to back up the droop screws to get more ride height.
