Like Tree5Likes
Old 07-30-2016, 08:24 AM   #496
Originally Posted by chris moore View Post
Thanks Cristian, the weight was one of my reasons for asking. I recently replaced most of the screws with aluminium ones and shaved 14 grams off, I'm now under weight with a CRC lightweight body but still over with a regular weight body. Looking at ways to get down to weight while using a Strakka and have been thinking about replacing my 9650.
Switching to a Sanwa SRG HS will save you 10 grams
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 07-30-2016, 09:45 AM   #497
chris moore's Avatar
Trader Rating: 87 (99%+)
Thanks Martin, 10 grams would be perfect.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 07-30-2016, 02:43 PM   #498
CristianTabush's Avatar
Default Official Pictures of the RR12 T2!!!
Many have copied the RR12's revolutionary concepts, but once again, RSD and it's team of developers are ready to raise the bar even further. The all new T2 includes the following updates:
-New and Improved Aluminum parts
-Std 7075-T6 Aluminum Chassis Made from Genuine Thyssen Krup materials,
-Std Weave Quasi-Isotropic Carbon Fiber parts
-AE Ballcups/ Pivots/ Links
-Standard sized servo mount
-RSD Damper Tubes
-Xenon Plastic Front End Parts
-New Motor Mount Compatible with 25-30mm fan (no thicker than 10mm) and adjustable motor height
-IRS ball differential with Xenon 16 Ball Spur Gear
-Team Prime Premium 12th Scale Shock
As with out RR12 V2, the T2 comes with our own proprietary double wishbone front end. . We do believe that the double A-Arm, once properly set up is faster than the traditional front ends we are all used to using. All our tests have indicated this so far. The Double wishbone front suspension makes the car easier to drive, is easier to set up and adjust, all while keeping a weight that is the same or lower as more simple front ends available in the market today.
The Big innovation this time around is the brand new, compact slider motor mount. This mount is lighter and has a much lower CG than the previous version, allows for the adjustment of motor height and also integrates fan mounting positions to keep your motor cooler during races. We have seen motor temperatures drop between 10-30 degrees Fahrenheit, which translates into a car that fades far less during an 8 minute race, especially in spec racing. The design was also optimized to make the motor mount have a better balance as well as have a more symmetrical design for more even turning left to right and a car that accelerates straighter than before.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 07-30-2016, 05:04 PM   #499
JimmyMac's Avatar
Looks pretty sweet!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 07-30-2016, 06:36 PM   #500
racer x 1's Avatar
Trader Rating: 27 (100%+)
Love the look on the T2. Any chance the manual will be posted? Wanna take a better look at the front end!
Matt Bell
Mugen MRX5 • Ae R5.2 • X6^3 • M11x • All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 07-30-2016, 08:19 PM   #501
Yes, just have to process the remaining pictures. It will get done this week.
Old 07-31-2016, 08:57 AM   #502
Default Congrats to Brett Dayton!
Congrats to Brett Drayton for winning Rd. 2 of the Asian On Road Championships in 10.5 12th scale with his RR12V2!
Thanks for the support! This is the RR12's first big international win!
Old 07-31-2016, 08:48 PM   #503
Dray01's Avatar
Thanks Christian. The V2 was on point all weekend! Super fast and consistent through the run. The driver came good by the finals Thanks for the advice leading up to the event!
Now I just need to find a way to hide the new T2 from the mrs
Dray01 is offline   Reply With Quote
Old 08-01-2016, 02:33 AM   #504
Jorge T's Avatar
Congratulations!!!.
Jorge T is offline   Reply With Quote
Old 08-04-2016, 06:43 PM   #505
Regional Moderator
disaster999's Avatar
You guys have a set date of when the manual for the 12th is going to be release?
Also seeing how you guys "officially" released the kit, I hope the kit comes in some sort of official box and not in a priority box with a few pieces of race day print out results as packing material.
disaster999 is offline   Reply With Quote
Old 08-04-2016, 07:02 PM   #506
racer x 1's Avatar
Any feedback for the T2 on the old style(grey) carpet?
Matt Bell
Old 08-04-2016, 09:03 PM   #507
The manual is almost ready. The pictures are all done and now just putting the file together.
The box is still the same white box we have always used. It would be nice to have a printed design box, but the cost is not something we can justify due to the limited production of the car. If we were making 300pcs per year it would be one thing, but we actually move much, much less units than that. When quoting boxes, they want a minimum of 1000-2000 boxes and that is simply not something we can affordbto do at the time. Our margins are extremely small on the car.
The T2 does really good on the grey carpet. It drives different than the V2, but it actually does very similar laptimes and some people actually prefer it as well.
Old 08-04-2016, 09:12 PM   #508
New car looks great, one question. Are the new motor mount /pod plates able to fit on the older V2 that I have?
Sponsered by:
Old 08-04-2016, 11:34 PM   #509
Yes, they will work. It does use a different rear cross brace though as the distance between the pod is less, with the T2 pod being 3mm lower, the T2 one won't work. However we have those available.
Old 08-05-2016, 05:02 AM   #510
Jorge T's Avatar
I run mostly 13.5 on Grey carpet.
I have a V2 with Xenon front end and a T2 with the IFS. My V2 is very stable and easy to drive.
From the get go I liked the T2. After some time with it I feel the T2 cuts in better and loving the IFS.
I'm a bit faster with the T2 at the end of the runs, as the fan keeps the motor from fading as much.
Both my cars are at 730gms.
RSD MS
