Like Tree5Likes
Old 03-21-2016, 06:29 PM   #436
chris moore's Avatar
Trader Rating: 87 (99%+)
Thanks,it's the CRC Lola body. Feels similar to the Strakka to me.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 03-22-2016, 10:58 AM   #437
landau's Avatar
chris
your girl is so cute! Can I borrow me?
landau is offline   Reply With Quote
Old 03-22-2016, 12:19 PM   #438
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
The CRC Lola is designed to feel similar to the AMR in terms of downforce and steering. The CRC Audi would be the comparable body to the Strakka.
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 03-23-2016, 08:49 PM   #439
Originally Posted by landau View Post
chris
Haha, certainly
You may be correct but thats the nature of RC, not everything works or feels the same to everybody. For me the AMR and Audi are not as easy to drive as the Strakka and Lola, ymmv.
Sponsered by:
Old 03-26-2016, 06:57 AM   #440
landau's Avatar
Thanks Chris.
I have been trying to test rear diffuser since EOS Rd2 RSD. EOS was 17.5.
I could not feel big difference, but it would be less tyre wear. I don't wonder the reason.
By negative pressure, I guess, it occurs less bumping during run.
Old 03-26-2016, 11:31 PM   #441
landau's Avatar
Hide Matsushima RR12V2. Now he on the race, EPS-J.
He hopes to use RSD Aluminum chassis, but it will be on shipping.
Appendix.
Yokomo R12 proto. This is TOTO's car, who is team yokomo driver.
This is Shizy Tanaka CRC, who is legend of 12th in JP and my best friend.
He started 12th racing by Delta since 1970'?. Very decent driver.
Old 04-05-2016, 04:07 PM   #442
racer x 1's Avatar
Trader Rating: 27 (100%+)
Anyone driving ab rr12 coming from an R5 or xti? Just looking for some input. Thinking about putting another pan car together
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 04-05-2016, 05:06 PM   #443
Trader Rating: 5 (86%+)
You won't regret it, car has so much corner speed.
Smithracer11 is offline   Reply With Quote
Old 04-05-2016, 05:28 PM   #444
I converted my 5.1 with the conversion kit, I only have one outing on it but really liked it.
Sponsered by:
Old 04-09-2016, 03:12 AM   #445
Dray01's Avatar
Hey guys,
What side tubes come in the kit? They are 4mm.
I clipped a board and broke one
Dray01 is offline   Reply With Quote
Old 04-09-2016, 03:05 PM   #446
landau's Avatar
Associated or On-point side tube in V2 full kit.
Old 04-09-2016, 03:11 PM   #447
Dray01's Avatar
Thanks! Guessing on-point as they are black and 4mm.
BD
Old 04-18-2016, 10:22 AM   #448
So was anyone running the RSD 12th this past weekend in Colorado? How was the car and any setups from the race?
Sponsered by:
Old 04-18-2016, 12:12 PM   #449
There was indeed a handful of them being ran at 5280. I'm not sure on setups or results though. I'm sure Christian will chime in with those when he gets home.
Old 04-18-2016, 12:58 PM   #450
bdmpastx's Avatar
Yeah he is driving back so it may be a while.
I was driving mine and it was fantastic. On my best run of the weekend, I was all set to qualify for the B but I rolled it after clipping the rail on the last lap and the corner assumed my race was over and it cost me my extra lap dropping me into the C. I ended up winning the C main...Oh well, it happens. I used JFT Dark blue fronts, glued on the outside and JFT pink rears. I sauced the tires 10 races before mine and wiped them 5 races in until they were almost dry. It was really dialed. I was running an older D4 13.5 I bought over a year ago and it couldn't keep up with the A main drivers with Motiv and Ready motors. I am just doing this for the hobby (fun of it) and I really don't spend a lot so I wasn't prepared to buy the motor of the month. I may have been down on power but it didn't ruin my weekend of fun.
As for the setup, I was running 3.4mm ride height, adjusted the springs to give me that height on the front, then adjusted the droop screws until it moved, then added a 1/4 turn of preload to it. So no droop. The rear was the same with about .5-.8mm of droop. This track is so smooth and the rear end of this car was stuck and the suspension seemed to like this. Our home track (RSD) is really bumpy in places and there is no way I could get by doing this there. The glue on the front was absolutely necessary on the black carpet. Either that or cut 1 run tires at 38.3mm. They both felt the same so I opted to go bigger at 39mm and glue to get more runs on them.
A lot of us in Texas have not been able to run on the black carpet, in fact almost all of us. Cristian and I only did it once up in Dallas at Banana so it was a leaning experience and we both walked away with more knowledge.
There off the top of my head, there were 6 RR12s there. There may have been one more.
bdmpastx is offline   Reply With Quote
