Like Tree2Likes
Old 12-25-2014, 12:02 PM   #31
Jorge T's Avatar
Some eye candy.
RSD RR12 12th Scale Pan Car Kit-img_20141225_135234.jpg   RSD RR12 12th Scale Pan Car Kit-img_20141225_135151.jpg   RSD RR12 12th Scale Pan Car Kit-img_20141225_135510.jpg   RSD RR12 12th Scale Pan Car Kit-img_20141225_135540.jpg
RSD MS
Jorge T is offline   Reply With Quote
Old 12-25-2014, 01:20 PM   #32
CristianTabush's Avatar
Originally Posted by InspGadgt View Post
Have you considered putting tape slots in the chassis so the in-line battery config can go on the right side of the car as well? Tracks like the IIC with a right hand sweeper would benefit from having the battery on that side.
Aren't most sweepers to the right? We have not tested in that configuration, but I would venture out to say that a car that is balanced left to right, there should be no difference in performance whether the battery is on the left side or right side. But, one of the advantages that we have is that we can offer customization to the cars' chassis as per customer requests. If this is something you want done, we can totally accommodate it.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 12-25-2014, 01:47 PM   #33
wingracer's Avatar
Trader Rating: 23 (100%+)
Here's a three year old post from Josh Cyrul on the subject:
I made the chassis adjustable for the track you race on - Example - Snowbirds (mostly left turns) put the pack on the left due to higher CG of the pack. IIC (mostly right turns) put the pack on the right... This is my .02 on this one.
As for me, I prefer good old transverse.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-25-2014, 02:23 PM   #34
I can't say that I necessarily agree with that. I don't think a battery has a higher CG than a servo or an esc like a HW V3.1 today. Perhaps 3 years ago, or with different electronics, this may be meaningful, but I don't think it is something easy to measure.
I could be totally wrong though, and if this is something people want available to them, we can again, add it.
Old 12-25-2014, 02:32 PM   #35
RCBuddha's Avatar
Trader Rating: 33 (100%+)
I'd like an F1 conversion with all the features the RR12 features.
RCBuddha is offline   Reply With Quote
Old 12-25-2014, 02:36 PM   #36
wingracer's Avatar
I'm kinda with you on that but would love to do an exaggerated test to confirm. Imagine two 40 gram weights. Mount one on the extreme right side of the car. Mount the other on the extreme left but on a really tall standoff. Something so high it sticks out of the body. Make sure the car is balanced and tweak free and run it. See if there is any handling difference left to right, then switch sides and repeat.
Team Shepherd USA
Old 12-25-2014, 02:58 PM   #37
I still don't understand what the point of the experiment would be. You won't ever be running an exaggerated set up if your car is balanced, so all practical applications of it are really not relevant.
RC Buddha, We plan to eventually make an F1 car down the road, as well as a World GT Car.
Old 12-25-2014, 05:54 PM   #38
303slowdown's Avatar
Trader Rating: 21 (100%+)
Are the conversions available now or at same time as the kits ?
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-25-2014, 06:06 PM   #39
Same time as kits.
Old 12-25-2014, 07:42 PM   #40
Jorge T
What center shock is that?
NCOHOG is offline   Reply With Quote
Old 12-26-2014, 02:54 AM   #41
The battery is taller so inherently the CG will be higher. Another thing to consider...going to the center mounted floating servo mount is to keep the chassis flex characteristics the same on either side of the chassis...The same would hold true with the slots for battery tape. Without the extra set of slots the flex characteristics of that part of the chassis will be different on each side of the chassis.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 12-26-2014, 06:31 AM   #42
EDWARD2003's Avatar
I doubt a small slot will change the chassis flex characteristics at all. The Yokomo C3 has a fair sized cutout for the servo saver. So far no one has made any judgements about it's flex characteristics.
EDWARD2003 is offline   Reply With Quote
Old 12-26-2014, 07:25 AM   #43
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
The battery is not taller then some of the newer ESCs, for example the HW ESC is roughly 2.5mm taller then any 1s battery. I can't speak for any other speedos but there are several others out there that are fairly tall as well.
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 12-26-2014, 08:41 AM   #44
slowpoke68's Avatar
Trader Rating: 28 (100%+)
Default rr12
i think you guys are taking it a little to serious.it would be nice to have a choice in which side you want the battery on.it all comes down to the driver and some good luck to win
coyote hobbies raceway,tq raceway,kenon hobby.apex speed shop
Airtronics m12s,hobbywing,schuur speed,associated b6 b5m t5m sc5m,mini z,ta05 v2,some rock crawlers,and still counting....
slowpoke68 is offline   Reply With Quote
Old 12-26-2014, 08:41 AM   #45
Ed and kave, thanks for your answers. This is essentially how I feel as well these issues.
We'll make a change on it, the pictures you see are still prototypes and I am still testing a few variations on the chassis before I settle in on a final "production" chassis.
One thing that I can add is that there is no need for tape when running the car inline. The Uni-mount doubles as a battery hold down when running the battery inline. You basically have to loosen the 2 screws on it at the bottom to slide the battery in and out, but once it is in place, the shock mounting hole section doubles as a battery hold down. This, when combined with the rear brace, locates and holds down the battery on the chassis without the need for tape.
