Like Tree5Likes
Old 02-29-2016, 03:11 PM   #421
clint's Avatar
Trader Rating: 24 (100%+)
Send a message via MSN to clint
Originally Posted by JimmyMac View Post
His motor looks like the Trackstar Hexitron sold at Hobbyking. As for the 9602 servo. The 9602 is a taller servo than the 9650, but the same width and thickness. The 9602 will just fit depending how you mount and shim it on the servo mounts. The issue will be which servo saver will you use. If you use an Xray servo saver, you will have issues with it hitting the damper tube. To get around this, you can attempt to mount the damper tube up front in the optional holes on the arms. Cristian can chime in on something he's working on as far as servo plates, but the 9602 will fit but not have much room to move around. It'll basically be in the same position as my 9650. If you have any more questions on this, just let me know.
I will be using a Kimbrough servo saver.
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 02-29-2016, 03:12 PM   #422
JimmyMac's Avatar
Actually it's Hextronix.... it's the name on the Roar website for the V2's.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 02-29-2016, 03:58 PM   #423
Dray01's Avatar
Cheers, learn something new everyday
Dray01 is offline   Reply With Quote
Old 02-29-2016, 04:20 PM   #424
CristianTabush's Avatar
Thanks for the feedback as always guys!
As Jimmy said, I am working on a Futaba servo mount that will have a single slot in between the 2 existing ones. Should have some ready to go in a day or two.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 02-29-2016, 04:27 PM   #425
landau's Avatar
I'm ready for next RSD race with RR-V2 aluminum and TR-V2 17.5.
This motor
stator length:20.3mm(not short stator, this maybe for dirt application)
weight:173g
timing/roll out: I will start at 43deg/87mm.
landau is offline   Reply With Quote
Old 03-05-2016, 06:08 AM   #426
landau's Avatar
My V2Al ready for race. But I'm distressing ESC.
1. Tekin RS with Lije booster: 731g, including 9g wight.
2. SMC RF-120 1S: 741g
Old 03-19-2016, 09:07 PM   #427
chris moore's Avatar
Trader Rating: 87 (99%+)
I was finally able to run my 12th car for the first time today. I bought a 12r conversion kit several months ago but with one thing or another I just have not had time to get it on the track yet. We do not have any full time tracks here, just one track that is put up and torn down each Sat in a local business parking lot. The asphalt is good but has some bumps so a tall ride height and full size tires are a must.
The first two rounds I had some body issues and other misc maden run problems but by the main the car was running great and felt great on the track. Kudios Cristian the car is a dream to drive and I'm looking forward to more track time with it. Now to finish the WGT build.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 03-20-2016, 01:54 AM   #428
Dray01's Avatar
Hey guys, curious what process others have been using to get the front height/droop set between runs. Personally I am doing the following:
- Back off droop screws,
- set ride height with fresh cut tyres
- set droop.
Cheers,
BD
Old 03-20-2016, 04:07 AM   #429
That's the best way to do it!
Old 03-20-2016, 10:49 AM   #430
Is the rear slider pod slip and change ride height after some good hits or one solid hit? Is it serrated?
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 03-20-2016, 02:40 PM   #431
JimmyMac's Avatar
It's not serrated. It's similar to the CRC. It just slides up and down. I haven't had any issues with it moving on me, but I haven't had any bad hits with it either.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 03-20-2016, 03:19 PM   #432
Dray01's Avatar
Cheers Christian.
BD
Old 03-21-2016, 07:38 AM   #433
idbdoug's Avatar
Trader Rating: 33 (100%+)
I got to test drive the RSD 1/12 this past weekend and it felt like I was driving a wgt, the car was that stable and smooth.
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 03-21-2016, 03:09 PM   #434
My RR12 as it hit the track this past weekend
Sponsered by:
Old 03-21-2016, 05:20 PM   #435
dirtdynamics's Avatar
Nice shell and Paint. Which shell is that?
dirtdynamics is offline   Reply With Quote
