Like Tree5Likes
Old 02-27-2016, 05:04 PM   #406
landau's Avatar
V2 with aluminum plate. Nice look!
landau is offline   Reply With Quote
Old 02-27-2016, 05:28 PM   #407
peter george's Avatar
Trader Rating: 336 (100%+)
Originally Posted by bdmpastx View Post
The car is revolutionary and I can almost bet money on it that XRay and/or CRC makes a similar version in the next year or so once they see how fast this thing can be around the corners. This car is one of Cristian's biggest accomplishments. I think Mile High will show that this year. I can think of about 6 will be there off the top of my head.
It won't be the first time some company steals / copies some idea off Cristian . BTW that car is sick looking , even upside down it looks fast
Team Underdog-Team UPURZ-Island Raceway & Hobby-If we trade lower feedback always ships first.#41-#18. Team Associated B6-B5m-CRC-Durango DEX210-DESC210-Intech-Tylenol-Pizza
peter george is online now   Reply With Quote
Old 02-28-2016, 04:33 AM   #408
EDWARD2003's Avatar
I got to see the V2 up close and it looks great. Sadly, I didn't get to see the innovative front end. The guy on his first run broke the lower carbon fiber arm.
Luckily he's ordered one and it will be arriving soon. The chassis design and layout looks great. Well done Cristian!
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 02-29-2016, 04:57 AM   #409
bdmpastx's Avatar
Damn, broke and arm? That's the first one I have heard of and I have seen some spectacular hits.
bdmpastx is offline   Reply With Quote
Old 02-29-2016, 07:03 AM   #410
CristianTabush's Avatar
Yes. Landau showed us on the arm breakage. It was with a modified motor and much harder barriers. The A arms have since been revised.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 02-29-2016, 10:37 AM   #411
landau's Avatar
The person, Tom Koyae said to me, it might be occurred at checking and rebuilding process before he run. He removed pivot parts from sus-arm and installed. There is no clearance between them, it need exactly straight install. He is waiting for new aluminum chassis and arm from RSD.
Anyway, how do you/Ed think about AXON Supper gear and Deff lube?
Old 02-29-2016, 11:48 AM   #412
Is the V2 compatible with a micro servo? As I see the mount has changed to 'standard' in the description.
BKUK is offline   Reply With Quote
Old 02-29-2016, 12:18 PM   #413
The car is actually optimal when you run an Airtonics 94761 or the Sanwa equivalent. These are about as small as they get when it comes to servos and are recommended to get down to minimum weight easier.
Old 02-29-2016, 02:28 PM   #414
Dray01's Avatar
Had another quick practice with the car last night. Car feels really positive with a ton of steering!
Car feels and looks great! Looking forward to some actual racing when the track is gripped up!
Thanks Christian!
Dray01 is offline   Reply With Quote
Old 02-29-2016, 02:41 PM   #415
clint's Avatar
Trader Rating: 24 (100%+)
Send a message via MSN to clint
Thanks Christian!
which turn V2 motor are you running? how do you like it?
Also you guys know if my Futaba 9602 servo will even fit in this car?
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 02-29-2016, 02:49 PM   #416
bdmpastx's Avatar
Yes^ on the Futaba 9602 we have a guy running one in his fine. I have both but I am running the Airtronics in there.
Old 02-29-2016, 02:52 PM   #417
clint's Avatar
cool..thank you sir!
Old 02-29-2016, 02:54 PM   #418
Dray01's Avatar
The v2 is actually better than you would think. I have tested reedy, Powers etc and this seems to have them covered. Especially at the end of the run. The 24k seems to be the motor to have though. We run euro stock 10.5. At the beginning of the run the guys with 24k are 3-5km faster on the straight at the beginning of the run. Please excuse my soldering.... Did it while jetlagged
Old 02-29-2016, 02:55 PM   #419
JimmyMac's Avatar
His motor looks like the Trackstar Hexitron sold at Hobbyking. As for the 9602 servo. The 9602 is a taller servo than the 9650, but the same width and thickness. The 9602 will just fit depending how you mount and shim it on the servo mounts. The issue will be which servo saver will you use. If you use an Xray servo saver, you will have issues with it hitting the damper tube. To get around this, you can attempt to mount the damper tube up front in the optional holes on the arms. Cristian can chime in on something he's working on as far as servo plates, but the 9602 will fit but not have much room to move around. It'll basically be in the same position as my 9650. If you have any more questions on this, just let me know.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 02-29-2016, 03:05 PM   #420
Dray01's Avatar
Not sure what the Hexitron is. Just know them as a v2. At our track i do give up a little to the guys with 24k but not too much.
http://www.hobbyking.com/hobbyking/s...approved_.html
