Like Tree5Likes
Old 01-29-2016, 08:45 AM   #331
masterhit's Avatar
Trader Rating: 15 (100%+)
Originally Posted by CristianTabush View Post
Mike, as for lead time. It depends on when you order. We assemble every kit as I don't have a manual for it, so the wait can be a bit longer.
Thanks for all the help! Ordered! Time to start obsessively checking the website for aluminum chassis pre-orders!
Mike
masterhit is online now   Reply With Quote
Old 01-29-2016, 09:08 AM   #332
chris moore's Avatar
Trader Rating: 88 (99%+)
Thanks Cristian, I'll make that change to the center shock before I hit the track. The new aluminum chassis looks awesome.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 01-29-2016, 09:23 AM   #333
CristianTabush's Avatar
And then there were 5! Thanks Mike. You are no.3 on the list.
Chris, my pleasure. As always, it's a preference thing and it depends in how you drive. For a lot of people a softer spring makes the car less aggressive, this is usually true for those that coast a lot. I am an on power driver, so typically the stiffer spring makes the car more stable at speed.
CristianTabush is offline   Reply With Quote
Old 01-29-2016, 12:20 PM   #334
RacinJ's Avatar
Christian, I noticed on the previous page that you had Contact "J" compound tires on your car. How do they compare to to JFT compound tires?
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 01-29-2016, 12:40 PM   #335
I had contacts on because I was out of JFTs
The contact is a more open pore tire that shreds a bit as it's running. The glue job is not the greatest, but in the right track conditions they can be just as fast. With the bigger pore, the car stays more on top of the track vs getting into it. They're ok, but they are not very tough.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
Old 01-29-2016, 01:08 PM   #336
RacinJ's Avatar
Thank you for the feedback.
Old 01-30-2016, 08:44 AM   #337
Only 2 unimounts left, so we got enough for only 2 complete kits left. Amazing! Thanks for your support, this will make it approximately 100 kits sold in 10 months!
Old 01-30-2016, 10:51 PM   #338
landau's Avatar
I have tried transverse battery position since maiden voyage, Then I am testing 1/4"forward battery position. This means 1/8" forward CG of this car. Approximately, I copy cristian setup, but every run I change and try other set one by one.
landau is offline   Reply With Quote
Old 02-01-2016, 01:35 AM   #339
Which bumper fits this car?
andrease is offline   Reply With Quote
Old 02-01-2016, 07:38 AM   #340
bdmpastx's Avatar
You need to cut your own bumper. The AE foam is too narrow now. Some are splicing and extending them. You can take a TC one and shape it to fit.
bdmpastx is offline   Reply With Quote
Old 02-02-2016, 03:22 AM   #341
Well, thank you.
Sometimes it takes a bit of modeling ...
Old 02-03-2016, 04:48 PM   #342
Does the version 2 kit have the adjustable wheel base?
X Ray X12'16
X Ray X12'17
Paint by Mikey
Boom RC
chodaboy is offline   Reply With Quote
Old 02-03-2016, 05:55 PM   #343
Yes, our slider pod design carries over from the V1 and allows for wheelbase adjustment by using shims to lengthen up to 3mm at the rear.
On another note, we are sold out of the new batch of cars, which starts shipping at the end of this week/ early next. Next batch will not be until March I think.
Old 02-03-2016, 05:58 PM   #344
bdmpastx's Avatar
There will be several of these at Mile High in April. I will have mine, not that I am fast or anything. But I will have one there as well as a few other drivers.
Old 02-04-2016, 08:09 AM   #345
Trader Rating: 18 (100%+)
i think by then i'll figure if i want to switch from CRC to a new pan car platform. I'll see how the guy here and his reflex runs
phatboislim is offline   Reply With Quote
