Like Tree5Likes
Old 09-23-2015, 04:39 PM   #271
EDWARD2003's Avatar
Originally Posted by InspGadgt View Post
They did away with the anti-roll bar because they went to a spring on each arm. If you use a single centralized spring then you would still need a roll bar. Running the spring inside the damper tube would be the same as a single centralized spring.
I wonder why they continued on with the anti-roll bar on the C3 and C3.1? It wasn't until just recently they did away with the anti-roll bar.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 09-23-2015, 04:50 PM   #272
bdmpastx's Avatar
I would imagine on a bumpy track the sway bar would cause the car to lose ground clearance and slow it down if the chassis touched the ground. Especially if you are running it low at 3mm.
bdmpastx is offline   Reply With Quote
Old 10-26-2015, 09:01 AM   #273
Jorge T's Avatar
My V2 chassis.
Inline configuration is so easy to drive, has mega traction and tons of corner speed.
540 Tuning
RSD
Jorge T is offline   Reply With Quote
Old 10-26-2015, 02:57 PM   #274
JimmyMac's Avatar
Must be nice. Wish I had mine!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 10-26-2015, 03:20 PM   #275
CristianTabush's Avatar
You'll get it soon. Just getting all the orders filled and yours will be otw. Jorge gets special privileges since he is my Dad
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 10-26-2015, 05:11 PM   #276
chris moore's Avatar
Trader Rating: 87 (99%+)
Originally Posted by Jorge T View Post
My V2 chassis.
Nice Which brand of wheel is that, I do not remember seeing a wheel that color before.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 10-26-2015, 05:48 PM   #277
303slowdown's Avatar
Trader Rating: 24 (100%+)
They look like jft's to me.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 10-26-2015, 06:09 PM   #278
EDWARD2003's Avatar
+1 There are other colours as well. Black, White, and Grey.
                 VBC 12M - D08 - FX
Old 10-26-2015, 07:05 PM   #279
Madulla's Avatar
My original chassis is completely tweaked. The carbon is bending so bad I can't even set it up anymore. Not sure how it happened. No one at my track has seen something like this. Any ideas what caused it? Should I just get the V2 carbon instead of replacing the chassis?
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 10-26-2015, 07:14 PM   #280
JimmyMac's Avatar
Well that explains everything!! haha Not a problem, mine has been doing pretty good so far.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 10-26-2015, 07:18 PM   #281
I have not seen this happen yet, but email me at the store and I will give issue you a coupon to save some money on a V2 carbon update kit to make it up to you.
Old 10-26-2015, 07:18 PM   #282
No worries, yours should be OTW tomorrow.
Old 10-27-2015, 04:43 AM   #283
Jorge T's Avatar
JFTs, I like the way they feel coming out of a corner compared to other brands, the way webbing is done in the rear wheels supports the wheel from the middle out. Contacts have a similar design but for some reason they tend to chunk more than JFTs
My original chassis(running 17.5 class) got hit by a mod TC 3/4 down the straight ( braked too late) and launched my car about 30 ft. in the air, hit the bay door and landed on the board. The pod plate broke, I fixed it but after that my car never drove the same.
After I built my V2, I noticed that my Original chassis did not tweak but it flexed a lot.
540 Tuning
RSD
Old 10-28-2015, 12:38 PM   #284
Thanks for the info, have not seen the JFT brand yet myself.
Sponsered by:
Old 10-28-2015, 01:51 PM   #285
Trader Rating: 21 (100%+)
I've never even gotten to race my v1 car yet as I received it on a Friday before my last race and the first race for me is still 2 weeks away. I will be waiting on the new front end as I'm very interested in seeing how it does in modified in theory should be a lot better. I did like Josh's car with the flex plates, worked very well for me. Just stopped driving it as parts were getting hard to get
Scirocco is offline   Reply With Quote
