Like Tree5Likes
Old 03-24-2015, 04:00 PM   #136
Trader Rating: 29 (100%+)
Originally Posted by CristianTabush View Post
Carbon is back in stock, so the kits are back up for ordering on the site. Right now, orders would have a 2-3 lead time. Until I can get caught up.
2-3 days or weeks? Just curious, I'm thinking of ordering a conversion kit for my old Xray.
branover is offline   Reply With Quote
Old 03-24-2015, 08:00 PM   #137
CristianTabush's Avatar
Days. Sorry. I am cutting chassis and lower pod plates tomorrow. This would allow me to ship a few conversions Thursday and Friday and kits probably Tuesday/Wednesday.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-24-2015, 08:45 PM   #138
geeunit1014's Avatar
Hope to see a few other cars at nats this week!
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-29-2015, 02:51 PM   #139
Default Mike Gee 2nd Place at ROAR nats!
Congrats to Mike Gee for finishing second place at the 2015 ROAR Carpet Nats with his RSD RR12. Starting from 5th on the grid Mike was able to maneuver his way into 2nd overall. Only his second "big" race with the car, Mike showed tons of speed and pace to keep up with the big boys. Good job Mike!
Old 03-29-2015, 07:04 PM   #140
Thanks CT! Once I got the power sorted out the car was plain awesome. If I had that rip in qualifying I could have likely qualified better and challenged for the win but 2nd from 5th was more than I could have hoped for. Once I get decompressed ill post my setup on here
Mike Gee
Old 03-29-2015, 07:08 PM   #141
Congrats mike, car looked awesome when I saw it yesterday.
Brandon
Old 03-29-2015, 07:14 PM   #142
bdmpastx's Avatar
Congrats to both!
bdmpastx is offline   Reply With Quote
Old 03-31-2015, 06:23 AM   #143
No worries 2 time national champ. You did us proud! Once you do recover we'll definitely love to see your set up.
It is really exciting to see our little car do so well, thanks for everyone's kind words.
Old 03-31-2015, 08:07 PM   #144
The setup I ended on was (special thanks to Keven H for the help!):
It should be noted the grip was super high! Some touring cars were traction rolling on the Solaris Hard spec tires, and even some pan cars traction rolled!
Front:
AE .018 springs
0.5* camber measured at wheel
0 Toe
5* caster (measured with rpm camber gauge or similar)
5* reactive
2mm shim on upper arms
1mm shim on lower arms
1mm shim on axle
kyosho 15k grease on kingpins
0 shims between upper arm and steering blocks
ae steering blocks
3.2mm ride height
0 droop
BSR team purple tires @39.8mm, SXT sauce 1/4
servo forward, links behind servo saver with 1mm shims
Center:
RSD purple spring
32.5 oil (I think? CT built the shock, i havent touched it)
shock rearward, 2mm on lower mount, 0mm on upper mount
transverse battery
speedmerchant .022 linear side springs, just touching for preload
xray tubes w/ AE 10k oil
3.2mm ride height
1-1.5mm droop
Rear:
Xray diff
3.2mm ride height
BSR green tires @ 40.8mm, SXT Sauce full
standard wheelbase shims
171.5mm width
PF AMR body
PCR 7000 battery
PCR Tuned D4 SS 13.5
Here is a video from A3, probably the best race of the weekend. I am the white nose/reddish pinkish tail
+ YouTube Video
Mike Gee
Old 04-27-2015, 10:44 PM   #145
Default New Development
Hi guys, wanted to leave you all with some pictures of a change we did to our cars recently for all of you to try.
In the pictures above, you can see how we have flipped the unimount 180 degrees in order to move the mounting point for the center shock further forward.
I really feel this change makes the car easier to push hard under high bite conditions. When used with combination with the XRAY side links (longer) and a stiffer center spring, the car lifted less, carried more corner speed and this allowed us to cut our lap times by about a tenth.
Old 05-04-2015, 07:00 PM   #146
chris moore's Avatar
Trader Rating: 87 (99%+)
So how is everyone liking their RR12 cars, I am considering a conversion kit and would like to hear thoughts from anyone that is running the 12r5 conversion.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 05-04-2015, 10:29 PM   #147
Unfortunate that nobody has put in their 2 cents so far, so let me at least give you my point of view.
Last couple of weeks we have had a couple of break throughs with the car that I think have made our stock set up even better and the car pick up as much as 0.15 seconds per lap on average over a run on a track that has slightly less bite. All these gains came from playing around with different length links and different, more forward shock position. When testing, I thought to myself, "this is really cool, the car is so versatile, I did all these changes on the car on adjustments that most cars don't have out there even as optional parts."
One of the guys testing with me said he was impressed with how the car had completely tranformed itself in handling characteristic from one end of the spectrum to the next. He actually said it felt like a different car altogether.
The floating steering provides the car with gobs of steering. Comparing traditionally mounted servos on some prototype configurations never provided as much steering as the floating mount. This was made even more evident on our upcoming World GT car. I personally run this car with 15-20% less d/r than with other cars. To me less d/r= more cornerspeed, which is a big plus.
Old 05-05-2015, 01:33 AM   #148
howardcano's Avatar
Trader Rating: 35 (100%+)
Cristian, why is the shock mounted with the body connected to the pod rather than the main chassis?
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 05-05-2015, 06:46 AM   #149
I feel the shock goes longer in between re builds this way. I did not notice any performance difference whatsoever.
What I notice is the shock in the other direction will have a dead spot at the beginning of the compression once the shock leaks a bit and gets a bit of air. This way seems to minimize it.
Old 05-05-2015, 07:59 AM   #150
Jorge T's Avatar
I was running it that [in Bold] way and you can feel the dead spot after the car had been sitting for a while after a rebuild. I would pump it 2-3 times before each run.
FWIW the cars with the new configuration were hard to keep up with on Saturday's Club race.
In the process of converting mine. My X10-15 is getting its links cannibalized while I wait for parts
RSD MS
Jorge T is offline   Reply With Quote
