Old 12-12-2014, 03:05 PM   #1
hoyt1967's Avatar
Trader Rating: 32 (100%+)
Default What material for track border?
We are getting a weekly winter on road racing session going, we have access to Fast track carpet, but I was wonder what works well for the track border (barrier) whatever the official term is. Something that can be taken apart easily and stored easily as we will have to tear down the track after we are done each time. Found this picture, was curious as to what you guys think will work well in our situation.
hoyt1967 is offline   Reply With Quote
Old 12-12-2014, 03:17 PM   #2
I have been to a track where they used semi-flexible black tubing of some sort (drainage or similar) and they bolted these down to the ground. It proved to be very popular as the tubing is a lot more forgiving compared to timber/steel and even hard crashes didn't result in any damage.
nitro_cortex is offline   Reply With Quote
Old 12-12-2014, 03:29 PM   #3
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
We use clicktrack with 2x4s as an outer barrier painted in tough enamel. If cost is an issue you could prob make your own clicktrack from pvc/ abs pipe nd stick it down with velcro.
My stuff
Sanwa M12 - Xray T4/16 - Xray Nt1/16 - CRC XTI-WC - ProAMPS - Hobbywing - ReVTECH - ORCA
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com
valk is offline   Reply With Quote
Old 12-12-2014, 03:44 PM   #4
hoyt1967's Avatar
FWIW guys this will be on a cement area so we cant bolt it down to the ground.
Old 12-12-2014, 03:52 PM   #5
some of the tracks here use round plastic pipe. heated to make curves etc. bolt together. one track uses heavy metal weights and fire hose rolled up to hold the track in place. this is on a parking lot. another uses go kart tires filled with concrete and a chain to pick them up with. works well.
dragonracing is offline   Reply With Quote
Old 12-12-2014, 04:28 PM   #6
DesertRat's Avatar
One way is to use aluminum rain-gutter drain pipe, which is roughly rectangular, loaded with something weighty, like 2x4's, and put the hook side of Velcro on the bottom of it, and put sand bags on top of the crucial corners. You can screw the whole thing together with self-tapping screws and good thing about this material is it gives in a wreck, and won't break cars as much as true immovable corners.
I race toy cars for fun. If I need to explain, you'll never understand.
If everything is under control... go faster.
WTB: Carpet racing in Arizona.
It is obvious and intuitive to the most casual of observers that RC racing is better than golf.
DesertRat is offline   Reply With Quote
Old 12-12-2014, 08:31 PM   #7
SWTour's Avatar
I like the white plastic Rain Gutter "Down Spout" that is about 3" x 3" square by 10 foot.
I bought about 40 of these for doing portable races , and found some that was just a little smaller, and cut those into 12 inch pieces, slid 1/2 way in to one end of each 10 footer for a joining tongue.
These look really similar to the CRC Click Track stuff and worked great for several years, and I believe they were less than $10 per 10 ft section.
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 12-13-2014, 08:26 AM   #8
GerryH's Avatar
Trader Rating: 18 (100%+)
1.5" Sch 40 PVC. You can create connectors using 1.25" Sch 40 PVC. Put a flat head screw a few inches in from the ends of your track pieces, making sure to orient them always in the same position.
On the connectors, mark and cut a corresponding slot and L to make a locking connection. Make sure to alternate the direction of the L on each end.
For corners you can purchase all sorts of curved PVC pieces. Online they are less than $1 per. On these pieces it's important that the locking screw is, for a lack of a better term, always on top.
I helped a friend build a whole track with this method. Think he said it cost him about $100 in parts. Yes it was a little time consuming to make the parts and you have to be careful when building the track because you rotate the track parts to lock, not the connector. But the sides and top are smooth, so you are less likely to break catching something. And it's a toolless set up and break down.
GerryH is offline   Reply With Quote
Old 12-13-2014, 01:00 PM   #9
SWTour's Avatar
I've done the PVC Pipe route too, You can get PVC Pipe in 20 foot lengths and as mentioned all kinds of curves are available - I like the downspout better because it's square vs. round, and it's lighter and easier to handle. (we have a 20+ ft trailer - so either way worked...) We also used regular PVC Rain Gutter - over lapped and screwed together. It works good for inner track pieces, but I still prefer the square downspout for the outer barrier.
Joe Myers
Old 12-13-2014, 02:35 PM   #10
hoyt1967's Avatar
That's great info. I like the downspout idea. Was actually thinking that last night.
Old 12-14-2014, 12:11 PM   #11
Square plastic down spout with a strip of hook velcro stuck on it will prevent it from moving on carpet.
For hairpin corners get a block of wood that matches the down pipe and screw a strip of 1/8" ABS on it so it forms a loop. This flapper means if a car hits the apex it will be bounced off rather than end up stuck on the racing line.
For more sweeping corners get two blocks of wood and screw different length strips of the ABS to it to make whatever curve you want.
terry.sc is offline   Reply With Quote
Old 12-14-2014, 01:55 PM   #12
ShadowAu's Avatar
I am investigating the same things as I try to come up with something cost effective for a temporary car park track (or basketball court track in my case).
Main issue I am have is that pvc pipe seems much more expensive here with a 3 meter length somewhere between $20 and $30 depending where I look
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 12-14-2014, 05:32 PM   #13
Cheapest way getting hold of the pipe is through a local builders merchant, especially if you know a builder who can order it for you. If you are ordering 50 or 100 metres of it you are going to get a much better deal through the trade.
Old 12-14-2014, 06:49 PM   #14
Odin544's Avatar
Trader Rating: 93 (100%+)
We just got all new barrier and went with 2-1/2 inch pvc downspout. Its flexible enough it doesn't break cars but durable enough that it doent break very easy. It's similar to click track but 1/2" bigger and 1/4 of the cost.
For corners I made some plywood corners that were adjustable so that when we change layouts we wont need to make anything new. For sweeping corners I took some thin plywood and cut 2"x8' strips. made a form at the radius I wanted and glued and stapled 4 strips together to slip inside the PVC that I'd made relief cuts in. Once the plywood is inside the PVC I screwed into the plywood with some screws and it held the shape of the plywood.
Our track is 96'x40'
As a bonus this was all paid for by local businesses sponsoring our onroad series. Huge thanks to them. Total cost was about $900 in materials.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 12-14-2014, 06:54 PM   #15
Odin544's Avatar
Everything is held to the track with 2"x3" Velcro strips. One strip approx. every 3' and on each corner. The weight of the corners help as well.
TriCitiesRC.com
SEO by vBSEO 3.5.0
