Old 12-14-2014, 06:48 PM   #16
volracer's Avatar
Send a message via ICQ to volracer
fire hoses filled with sand
volracer is offline   Reply With Quote
Old 12-15-2014, 08:57 AM   #17
hoyt1967's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Odin544 View Post
We just got all new barrier and went with 2-1/2 inch pvc downspout. Its flexible enough it doesn't break cars but durable enough that it doent break very easy. It's similar to click track but 1/2" bigger and 1/4 of the cost.
For corners I made some plywood corners that were adjustable so that when we change layouts we wont need to make anything new. For sweeping corners I took some thin plywood and cut 2"x8' strips. made a form at the radius I wanted and glued and stapled 4 strips together to slip inside the PVC that I'd made relief cuts in. Once the plywood is inside the PVC I screwed into the plywood with some screws and it held the shape of the plywood.
Our track is 96'x40'
As a bonus this was all paid for by local businesses sponsoring our onroad series. Huge thanks to them. Total cost was about $900 in materials.
That is really sweet!! Nice work, beautiful track and thanks for that post.
hoyt1967 is offline   Reply With Quote
Old 12-17-2014, 03:18 AM   #18
hanulec's Avatar
Trader Rating: 25 (100%+)
i like the look of that square pipe cut into a bend.
any square pipe should do -- the problem is corners. i enjoy farm plow dots to build out corners. they save $$ on racers bodies. this is how most euro tracks do it..
sweepers can be built using plastic molding cut to your track border height.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-17-2014, 07:58 AM   #19
Trader Rating: 29 (100%+)
Gutter Down Spouts are the cheap alternative to Click Track.
Race19s is offline   Reply With Quote
