Old 10-06-2002, 05:10 PM   #1
madweazl's Avatar
Default M8 question
Buying an M8 and was wondering if there was a cheaper/better alternative to the Airtronics rechargeable setup. They want about 50 bucks for the battery plus the cost of the charger and its only around 700mah.
I saw somewhere people were using the 1800mah Orion AAs, is there a way I can charge these on a Super Brain 959 without soldering them together making a pack?
Appreciate any suggestions, Aaron.
madweazl is offline   Reply With Quote
Old 10-06-2002, 08:44 PM   #2
TRF414M's Avatar
You can get the battery tray which you can get the adapter to fit in the bottom of the battery tray. Then, as long as your charger is capable of charging 8 cells, then you will fine.
TRF414M is offline   Reply With Quote
Old 10-06-2002, 09:25 PM   #3
Speedo's Avatar
R/C Tech Charter Subscriber
go to radio shack and you can get a tray for 8 AA batts, with knobs on the top for pos. and neg. If you use the airtronics tray pluging in at the bottom, you run the risk of melthing it
Speedo is offline   Reply With Quote
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 08:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 05:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 08:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 11:46 AM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 09:33 AM
SEO by vBSEO 3.5.0
