Old 12-03-2014, 09:16 AM   #1
Default MI5 Evo setup help
Hi
I was hoping someone experienced had a setup they would recommend for a MI5 evo that will run carpet. I will be running "Mod" motor.
MatsNorway is offline   Reply With Quote
Old 12-03-2014, 11:22 AM   #2
Default Hvor kj°rer du
Hei
Norsk?
Originally Posted by MatsNorway View Post
Hi
H
Viking73 is offline   Reply With Quote
Old 12-03-2014, 02:18 PM   #3
TryHard's Avatar
Have a look on here. I believe Nikolai's setup (latest one in the carpet section) is pretty damn good.
http://www.petitrc.com/reglages/schu...macherMI5.html
Ed
Old 12-04-2014, 08:38 AM   #4
Thank you. Bang on the money and Viking73 sendt me the same one. I just did not know where to find such things.
Will order new stabilisers. And add chims to suspentions to get the dive etc right.
But im confused about the oil. Stock is refered to as 35W. Setup sheet has 350cTs? same just different unit?
I also have a ton of old losi oil.
20, 40, 50, 60, 80 it says on the top. It is also color coded. Is the number values to be considered in W's whatever that is.. viscosity value? why W?
Old 12-04-2014, 01:32 PM   #5
TryHard's Avatar
He is using a different brand oil (MuchMore), which will be a bit different to the kit 35wt. It's very hard to transfer a wt measurement to cst.
In terms of the Losi oil, I personally always found it to be quite thick for the rating. 35wt Losi is not too dissimilar to 450cst MuchMore. Personally, if you can, just grab some bottles of cst rated oils, and your set (normally not that expensive, probably only need 350,400,450,500). Just make sure to use the same brand oil for the different rates, as there can be big differences between one brands oil and another's.
HiH
Ed
Old 12-04-2014, 01:40 PM   #6
Default Its a very good allround setup i would say, but you go to NC2 Mats?
If you go to the race just come over and we will get your car sorted!
NikolaiHaheim is offline   Reply With Quote
Old 12-04-2014, 04:16 PM   #7
TryHard's Avatar
Double post
Old 12-05-2014, 05:11 AM   #8
Thanks for all the help. At rcmart now buying shims and oil. I won't be racing anytime soon. Goal is some hundreds of laps first and really nailing down a setup i feel comfortable with. Then we can talk lisence.
Old 12-08-2014, 02:42 AM   #9
hydrakermit's Avatar
Found this, Hope this helps people.
hydrakermit is offline   Reply With Quote
Old 12-21-2014, 08:31 AM   #10
Thanks!
Old 12-22-2014, 07:00 AM   #11
Damon's Avatar
also Hofer's last setup is very good, exspecially for Ride tires, I think that Nikolai's setup is derived from this, there are many similarities
http://www.petitrc.com/reglages/schu...ing2014091921/
you can consider the alluminium chassis and Yokomo blue springs also in front (with shocks in central hole on tower)
Awesomatix A800
Awesomatix A800X
Damon is offline   Reply With Quote
Old 12-22-2014, 08:55 AM   #12
Sorex. Sorex only for me. Alu chassie? Why what?
Old 12-23-2014, 06:42 AM   #13
drive one this weekend.... rear end was planted!!
Gordie
Gordie88 is offline   Reply With Quote
