Old 12-02-2014, 01:25 PM   #1
Trader Rating: 23 (100%+)
Default Deans vs Bullet connectors
Hi all, I am currently using deans plugs on all my equipment and am considering a switch to bullets. Rationale being slight weight saving, cleaner wiring jobs. I run 17.5/13.5 TC, may be looking to modified in the future.
I see all the top runners using bullets, and this is why I am considering the switch also.
However I have read from Danny@SMC that inboard packs have higher IR ratings and lower voltages?
Considering the expense and effort required to switch all my gear to bullets... This seems like a step backwards to me.
Can someone explain to me why bullets are so popular over deans if they aren't as good performance wise?
Zhangesh is offline   Reply With Quote
Old 12-02-2014, 01:45 PM   #2
Trader Rating: 29 (100%+)
There are less breaks in the wire. The bullet female bullet is part of the pack and the male is the only solder joint between speedo and battery. As far as low IR ratings and voltage I call BS. My packs charge out to 4.2V per cell, every time, and most have an IR of less than 2
Race19s is offline   Reply With Quote
Old 12-02-2014, 01:54 PM   #3
samnelso's Avatar
cleaner, no balance wire, possibly lighter, possibly lower cg
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 12-02-2014, 02:28 PM   #4
wingracer's Avatar
Trader Rating: 22 (100%+)
Years ago when I did a bunch of testing with a turbo35 all my deans packs had much better numbers than the bullet pack despite the bullet pack being a newer and better pack. I soldered some bullets right down into the pack and hardwired it. Numbers went up significantly. So now that's what I do but I'm crazy like that.
I'm sure more modern bullets are probably better but I'll keep hardwiring. Why bother with connectors when I only change packs every year or so?
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-02-2014, 03:33 PM   #5
Odin544's Avatar
Trader Rating: 93 (100%+)
Please post a picture.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 12-02-2014, 04:51 PM   #6
You will notice no performance gain from one to another. Bullet connectors just look cleaner. Lap times will prove everything.
Juan Aveytia is offline   Reply With Quote
Old 12-02-2014, 04:55 PM   #7
Hmm seems like i should just wait till I start replacing my batteries. Thanks guys
