Old 06-28-2015, 01:29 AM   #61
mac853's Avatar
Originally Posted by b20btec View Post
The shocks are TRF short big bore and the springs are Ride shorty, if I'm correct 23mm long. The Xray springs are too short for TRF big bore. I extended the shocks to get desired droop.
You're not using a screw to mount the fan? Any reason for this? Parts available? The vibration from the fan running must be very noticeable.
I say use whatever lipo you want. Tested the car with long and short and I like both, I don't have a square lipo so I can't comment but it should before similar to the shorty.
In fact i use short dampers but not big bores, due swap from my tb04 which i no longer run.
Honestly, i try use ride short springs, but failed due the diameter are too large without plastic rings.
I use nylon ties instead of screws, due that part is easy to suffering on crash.
From my latest try with Yokomo short shocks, i can say they work perfectly
mac853 is offline   Reply With Quote
Old 06-28-2015, 02:29 PM   #62
mac853's Avatar
Originally Posted by Quinny45 View Post
First race day today and ho my god !!! I just want put my tamiya FF03 in the trash !!! only 0.4 sec of my sedan in usgt !!!
I run stock setup exept ajust camber and droop
remove the Oring ( bump stop ) on the shock shaft
remove ackerarm shims
optional rear short shock tower
orca Vx esc
sanwa ers-971 servo
Intellipeak 3300 80c 150g shorty pack
Hobbywing V10 21.5 full timing
52/96 64p ( 3.5 fdr )
HPI honda civic SI 190mm body
1220g reedy race !
next step Teampower 21.5 + 12.3 rotor , Fantom racing 3800 100c shorty pack 156g
Wait, you mean short shock tower for MTS?
Can you tell me where did you see that, please?
Old 06-28-2015, 07:21 PM   #63
Trader Rating: 4 (83%+)
http://www.race-opt.com/product/MTS%...t-04172015.pdf
M-128106 5mm shorter
and I have the aluminum chassi but not tested yet !
http://www.rcfunny.com/goods-2199.html
Xray T4 2017
Yokomo BD7 2015 Spice FWD
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Quinny45 is offline   Reply With Quote
Old 06-28-2015, 07:46 PM   #64
mac853's Avatar
Thanks for share, BTW i don't think that i need opt. tower, since i even need use yokomo short shocks which can fit normal length springs. My best thing to do is extend the shocks as b20 did which has same problem.
About alu chassis, i used before on med. traction carpet race but don't have good impressions.
Old 06-28-2015, 07:49 PM   #65
why you change the oem shock ? my car feel really good with the stock setup !
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 06-28-2015, 08:17 PM   #66
mac853's Avatar
I guess this is the best thing to do since you buy a chassis Made in China.
Old 06-29-2015, 05:15 AM   #67
b20btec's Avatar
I was going to use them but I couldn't adjust the eyelet. My kit came with the eyelet CA and the shock lengths were really off.
I've never driven any other FF but so far i'm happy with the performance. I can't really complain for price and performance this car is a winner.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 06-29-2015, 05:18 AM   #68
b20btec's Avatar
True about the ride springs, if I didn't have the big bore's it wouldn't work. Good idea about the zip ties, I can see potential death to the fan crashes.
Soap
Old 06-29-2015, 07:18 AM   #69
i will probably install tamiya std leight shock with stock spring. I have a works edition set for spare !
Xray T4 2017
Yokomo YR-10F F-1
VBC FF17 FWD
VBC FXM F-1
Old 06-29-2015, 07:32 AM   #70
b20btec's Avatar
I'm sure you already know, the TRF shocks are super smooth. It ran really well with zero rebound on this large outdoor track.
Track I tested it on. I didn't race because entry was too low, instead focused on my 17.5 TC.
Soap
Old 06-29-2015, 08:00 AM   #71
patorz31's Avatar
Nice Track where is it? what size is it?
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 06-29-2015, 09:43 AM   #72
b20btec's Avatar
Gulf Coast Raceway, Porter Texas
I don't know the exact dimensions but it's effn huge, in 17.5 TC I was geared 3.3-3.4 FDR and it wasn't enough.
Soap
Old 06-29-2015, 11:57 AM   #73
patorz31's Avatar
Yeah it looks way bigger then ours. ours is 140 x 80
Old 06-29-2015, 06:26 PM   #74
mac853's Avatar
I remember in 21.5 blinky somebody with serpent FF ran with 2.5 fdr but i just run 2.8 fdr.
Old 06-29-2015, 06:27 PM   #75
mac853's Avatar
Repeat
