Old 05-23-2016, 07:23 PM   #166
Originally Posted by benTC5 View Post
Anybody knows where in the world I can get a spare Chassis for my FF Pro? Nothing on Race-opt`s website! I have e-mailed them and heard nothing yet.
Do you need a chassis for the new car or the older one?
WWW.DISCHARGERC.COM
U.S. DISTRIBUTOR FOR RACE OPT BRAND
DischargeRC is offline   Reply With Quote
Old 05-23-2016, 09:51 PM   #167
marshallsbbq's Avatar
Trader Rating: 39 (100%+)
Default MTS FF PRO V2
Just got both the V1 and V2. I am going to do comparison of the 2. Already noticing both cars need to be completely rebuilt. I'd think they would do better off and not even build the car for you. There are some build problems like not all the shock shafts are the same length, the droop screws are crooked, and it looks like it's just rushed. I believe with all the battery modifications they should have had it where you can put the shorty pack even further back. The car needs alot of rear weight. Car wants to spin out off power in mid turn. Going to make some adjustments to tune that out. The car is fast, faster than my Sakura FF, Tamiya FF04, or my Top Racing FF. Will post picks and set ups as I run it more.
marshallsbbq is offline   Reply With Quote
Old 05-29-2016, 08:44 PM   #168
Older one, but as I said the new chassis plate looks the same as the old one? Am I correct?
benTC5 is offline   Reply With Quote
Old 06-02-2016, 06:26 AM   #169
No, the chassis' are not the same. The new Chassis uses split front and rear suspension mounts, the old chassis used a one piece That is the main difference.
WWW.DISCHARGERC.COM
Old 06-21-2016, 06:32 PM   #170
mac853's Avatar
Could anybody tell me, in case i use Xray diff with xray driveshaft, which length of ecs ones(50 or 52mm) i should use, please?
Best regards
mac853 is offline   Reply With Quote
Old 06-21-2016, 06:34 PM   #171
mac853's Avatar
Originally Posted by b20btec View Post
Looking to get a FWD body, I've seen a prius body but don't know who makes it, anyone got any ideas?
Is r246, but is very rare to find in Japan.
Even has selling got in the Japan shops are those prepainted ones.
Old 07-10-2016, 11:37 AM   #172
Anyone have a good setup for the car, outdoor asphalt track. What oil you guys running in the diff?
SRJRacing is offline   Reply With Quote
Old 08-24-2016, 06:54 PM   #173
Here's some setup sheets for the MTS FF V2
https://drive.google.com/file/d/0BxU...lNYWwzcU0/view
https://drive.google.com/file/d/0BxU...xIZzFFRm8/view
Diff oil run 1000000
Picked up the car recently. Based of T4 parts so I believe the arms and hubs are interchangeable at least. Not sure about the diff and drive shafts. Will get there when I need to.
Car basically needed to be rebuilt when bought. Don't understand why it's ARR. Everything had some bind in it so reaming, some light filing etc was needed but at least it wasn't sloppy! I changed to ti turnbuckles and ball cups to x-ray ones.
We'll see how it goes this weekend
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 11-09-2016, 12:29 PM   #174
Heathen's Avatar
What are peoples set up for indoor carpet these days?
Addicted since 1995!!
VBC D07, VBC D08, MTS FF Pro, Calandra 1/12 XTi, SCMT Warpath, AE RC8B3e
Heathen is offline   Reply With Quote
Old 11-12-2016, 10:50 PM   #175
http://site.petitrc.com/reglages/rac...ptMTSFFV2.html
Arn0 is offline   Reply With Quote
Old 11-13-2016, 11:44 AM   #176
Heathen's Avatar
So you are using the asphalt set up carpet?
Old 11-21-2016, 11:25 AM   #177
Best regards
I have upgrade my MTS's suspension to xray and used the 52mm xray shafts. Everything fits perfectly
Old 12-06-2016, 05:56 PM   #178
mac853's Avatar
Sorry, i mean ECS drive shaft, not suspension!
Anyway, thanks.
About another problem, in fact if i use Xray ECS and diff then i need to swap entire parts of T4(C hub, steering knuckle) in to MTS.
Could anyone tell me if i change entire steering parts would change drastically MTS behaviour?
Thanks!
Old 01-03-2017, 02:08 AM   #179
I will test my car this weekend (hopefully). When using the xray diff you have to use the MTS diff 'cups' (the plastic part that fits over the bearings) otherwise the diff binds. I've used 50mm xray shafts, I can't see why you cant use the 52mm ecs shafts, everything is xray so should work. I have also used xray shocks, 100 times better than the mts shocks.
Keep in mind when doing the swop/upgrade, the bearings in the steering block is different, so when you upgrade the steering blocks you have to use the xray shafts and then you have to use a xray diff as the shafts do not fit perfectly in the MTS diff.
Old 01-03-2017, 02:10 AM   #180
Thanks!
I think the only difference will be the that the suspension parts won't be as brittle as the stock mts parts and xray parts are freely available. Will report back on the behavior once I put the car on the track
