Old 11-24-2014, 07:18 PM   #1
EDWARD2003's Avatar
Default Brushless Motor Phases Important To A Motors Performance?
I recently picked up a motor checker and checked my brushless motors. At hand I have a batch of 21.5's such as; D3.5, MMM, R1, Tekin, G-Style, and Orca. I did some timing tests for these motors and came across some motors with A B C phases that were out by only a 1 or 2 degrees. However, I had some motor phases out by 10+ degrees.
For example I've tested a motor with A 23* B 39* C 42*. As you can see there is a big variance in timing at each phase.
Now, does this matter in the motors overall performance?
EDWARD2003 is offline   Reply With Quote
Old 11-24-2014, 08:02 PM   #2
DesertRat's Avatar
The short answer is yes, the difference in timing between phases will affect things like free-spinning RPM and amp draw, which translates into the power band on the track. You want all of the phases to be the same timing.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 11-24-2014, 08:12 PM   #3
EDWARD2003's Avatar
Thanks. So if the hall effect sensors spacing is not 120* from A to B to C. Then how is the motor going to effectively detect the proper rotor position? Then how is the motor going to apply proper positive and negative torque?
Old 11-24-2014, 08:32 PM   #4
EDWARD2003's Avatar
I did a test on a Team Powers Actinium 21.5 and it was by far the best motor. The phases were A51* B51* C50*. Cant get any better than that. Interestingly, the motor was very smooth and quiet.
Motors with greater variances in timing between phases sounded rougher and louder.
Old 11-25-2014, 01:13 AM   #5
Roelof's Avatar
Send a message via ICQ to Roelof
So it is time the next generation ESC's do detect the timing of the sensors and put those parameters into the program for an optimised control.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 11-25-2014, 03:35 AM   #6
Essnowyt's Avatar
Send a message via AIM to Essnowyt
delete.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
