Old 09-20-2005, 07:50 AM   #1
Default HPI rubber tyres + HPI inserts
Guys have you tried these are they any good when you compare them to others ?
Thanks for looking
speed6 is offline   Reply With Quote
Old 09-20-2005, 07:54 AM   #2
Registered User
I run on carpet. I have tried several HPI compounds, and several inserts and they have been decent quality and traction but no real advantage to buying pre glued RP30's which I prefer. Actually, I liked the CS27's more than my combo's with HPI stuff. The inserts and tires are high quality, but nobody carries them locally, more work for no advantage.
Desolas is offline   Reply With Quote
Old 09-20-2005, 12:26 PM   #3
I run a couple of hpi super slicks and sorex slicks. I think sorex have a little more traction but hpi last longer. (no matter of compound) By the way, I run on asphalt only. How many runs are you using slick tyres?
deepfree_z is offline   Reply With Quote
Old 09-21-2005, 01:17 PM   #4
I am new into electric and we are HPI dealers so i wanted to know what they offer next to Take Off and Sorex .
Old 09-22-2005, 07:27 AM   #5
Pro Models's Avatar
Hi Speed6,
Knowing that most probably you will be using these tyres at our local track at Pembroke I suggest you stick either take-off cs22s or Sorex 28r or even 24r if you have loads of cash to burn .
These are the only tyres that will work if you are after top performance. CS 22s will give u 3 good runs in a row with very constant lap times. Sorex 28r's will give you a blinding first run and then start to taper off as regards to grip.
I have tried out numerous tyre combinations including HPI tyres and Inserts but nothing will perform as well as the tyres mentioned above. If you need any help feel free to contact me via email or pm me on this thread.
Bye for now hope to see you at the track....Gustav
Pro Models is offline   Reply With Quote
Old 09-22-2005, 09:47 AM   #6
Traxxas makes some really cool tread designs, you guys should check them out!
1fsttraxxas is offline   Reply With Quote
Tyres, Inserts, Rubber Tyre Lathe.......................FOR SALE 2-Bad Australia For Sale/Trade 3 04-01-2008 03:00 PM
Rubber Tyres and inserts theory Drewdc90 Electric On-Road 5 06-11-2006 08:02 AM
T.O.P. Tyres/Inserts F. Alonso Electric On-Road 11 03-01-2006 04:48 AM
Foam tyres or rubber tyres at IFMAR? habicht Electric On-Road 1 06-16-2005 10:02 AM
Newb needs help with tyres/inserts MrRolla Australian Racing 4 04-20-2004 07:09 AM
SEO by vBSEO 3.5.0
