Old 11-01-2014, 09:00 AM   #1
Default wheels spinning on hex drives
Don't know if this has been discussed before but advise is needed please. I am running the new tamiya evo 6 on carpet with 17.5 blinky. Car is pretty much standard set up and have been running it for about 6-8 weeks. Issue I have found with it is the front wheels are starting to spin on the hex drives. I'm running sorex 32 any ideas?
gunjack is offline   Reply With Quote
Old 11-01-2014, 10:28 AM   #2
Could be a couple of things. Either the hex on the rim is not sized correctly or the rim plastic is too soft and allowing the hex to move.
HawaiiBob is offline   Reply With Quote
Old 11-01-2014, 11:45 AM   #3
Xpress's Avatar
Get new wheel nuts. Preferably the serrated type.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 11-01-2014, 12:48 PM   #4
Cheers guys. Car has serrated wheel nuts already on but have just ordered some more just to be safe. Maybe it's a bum set of wheels, although the rears are fine, will try some new wheels as well.
Old 11-01-2014, 03:02 PM   #5
avs
avs's Avatar
most sedan wheels have a significant overlap with the hex drive. it seems hard to imagine the wheel slipping without there being obvious damage.
but if the rears are ok, then try switching front to rear and verify it is the wheel. are you certain that the hex drive is not slipping on the drive axle?
Tony Shimko
avs is offline   Reply With Quote
Old 11-01-2014, 05:27 PM   #6
Xpress's Avatar
If you're using wheel track spacers replace them with wider hexes...
-Espo
Old 11-01-2014, 07:20 PM   #7
Tamiya - Awesomatix - Orca - Orion - LRP - Protoform - Sanwa - Futaba - NASA - Ride
Minami is offline   Reply With Quote
Old 11-02-2014, 01:29 AM   #8
asw7576's Avatar
Yes , absolutely.
I think this is gunjack's problem in the first place. You have to use wider wheel hex if wheel spacer is thicker than 1.5 mm.
Old 11-02-2014, 12:12 PM   #9
fullout's Avatar
Send a message via MSN to fullout
I find this can be common with a spool, especially on high grip carpet. Tighten the front wheel nuts really tight.
fullout is offline   Reply With Quote
Old 11-02-2014, 03:20 PM   #10
Have been using 5mm hex with the 1mm spacer. Will try without the 1mm spacer.
Old 11-02-2014, 07:00 PM   #11
asw7576's Avatar
Yes, it's common sense .... if you measure the depth of hex inside sorex rims , is only 3.6mm depth.
