Old 10-28-2014, 02:14 AM   #1
Odin544's Avatar
Trader Rating: 93 (100%+)
Default gluing touring car tires to prevent traction roll
When you glue touring car tires to prevent traction roll, what's your application method to get a nice even bead around the tire? Q-tip?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 10-28-2014, 02:44 AM   #2
EDWARD2003's Avatar
I'm surprised no tire company has invented stick on CA adhesive rings for tire sidewalls. Stick the rings on and wait 15 minutes, boom, your done! Nice, clean CA ring around the tire side wall. Same with rims, incorporate CA adhesive strip along the contact edge of the rim. Pop on your tire wait 15-20 minutes! Boom, you're done.
EDWARD2003 is offline   Reply With Quote
Old 10-28-2014, 04:34 AM   #3
Chaz955i's Avatar
Soak end of Q-tip with CA. With car on stand use a nut driver to spin wheel. I can get a very uniform, thin even bead on the sidewall. Dries very quick if it isnt globbed on.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 10-28-2014, 08:25 AM   #4
EricPF's Avatar
I might be slightly biased but Pro-Line glue with their yellow glue tips work awesome for this. Used them all week long at IIC.
http://prolineracing.com/pit-gear/pro-bond-tire-glue/
Eric Epp
PROTOform Race Bodies // racepf.com
EricPF is offline   Reply With Quote
Old 10-28-2014, 08:39 AM   #5
RobS's Avatar
Proline glue is awesome... Can't go wrong! I also use it to fix the carpet tears at our track.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
